HELP_Connect lte router to wifi router with a single utp cable (PoE)
Hello All,
I would like to ask your help, to be able to connect RBwAPR-2nD&R11e-LTE router to RB951Ui-2nD wifi router.
The trick is that I cannot power up (too complicate to make power under the roof) the LTE router with power supply only trough PoE.
The wifi router PoE out port is port5 and internet port is port 1, I would like to set port5 as internet port cause i need the PoE to power up LTE router.
Only want to use wifi of the wifi router so I don’t care the LAN ports.
really appreciate your help if you able to tell me a quick and easy way to do this configuration as I’m not expert to configure routers.
Cheers
