help converting wan failover, not working after ros7 upgrade
I need help converting my failover to ros7
below is the script i have been using but after upgrading to 7 the failover no longer works some options lost
add comment=“” gateway=
add comment=“” gateway= routing-mark=backup-rmark
/ip route rule
add action=lookup-only-in-table comment=backup-rule src-address= table=backup-rmark
/ip firewall mangle
add action=mark-routing chain=prerouting comment=backup-failover-nat disabled=yes new-routing-mark=backup-rmark src-address-list=
/tool netwatch
add down-script=“/ip firewall mangle enable [/ip firewall mangle find comment~"backup-failover-nat"]” host= interval=5s timeout=30s up-script=
“/ip firewall mangle disable [/ip firewall mangle find comment~"backup-failover-nat"]”
add action=src-nat chain=srcnat routing-mark=backup-rmark to-addresses=
add action=src-nat chain=srcnat src-address-list= to-addresses=
I have tried the following config but am unable to ping any outside IP unless i use the interface Ip itself and then only to thenext hop
add address=12.12.12.3/29 comment=“Pri-Ckt-AT&T” interface=sfp-sfpplus2
add address=12.13.14.34/29 comment=“BackUp-Ckt-Spectrum” interface=sfp-sfpplus3
/routing table
add fib name=backup-rmark
/routing rule
add action=lookup-only-in-table comment=backup-rule src-address=12.13.14.32/29 table=backup-rmark routing-mark=backup-rmark
add comment=Pri-Ckt-AT&T distance=1 gateway=12.12.12.1
add comment=BackUp-Ckt-Spectrum distance=2 gateway=12.13.14.33 routing-table=backup-rmark
/ip firewall mangle
add action=mark-routing chain=prerouting comment=backup-failover-nat new-routing-mark=backup-rmark src-address-list=NAT-General-list
/tool netwatch
add down-script=“/ip route set [find where comment="Pri-Ckt-AT&T"] distance=3;\r
\n:log warning "Pri-Ckt-AT&T 5Gig down, switching to Backup-Ckt-Spectrum 2Gig"” host=9.9.9.9 interval=7s up-script=
“/ip route set [find where comment="Pri-Ckt-AT&T"] distance=1;\r
\n:log warning "Pri-Ckt-AT&T 5Gig restored"”
add down-script=“/ip firewall mangle enable [/ip firewall mangle find comment~"backup-failover-nat"]” host=1.1.1.1 interval=
5s up-script=“/ip firewall mangle disable [/ip firewall mangle find comment~"backup-failover-nat"]”
add action=src-nat chain=srcnat dst-address-list=!VPN-Networks out-interface=sfp-sfpplus3 routing-mark=backup-rmark to-addresses=12.13.14.34
add action=src-nat chain=srcnat dst-address-list=!VPN-Networks out-interface=sfp-sfpplus2 src-address-list=NAT-General-list to-addresses=12.12.12.3
