Help getting IPTV-Multicast working on Audience
Hello, as i keept experiencing power issues with my RB-750GL i’ve decided to replace it with a Audience. So far the Audience works exelente. However with the RB-750GL IPTV worked, but im at a loss with the Audience. I’m pretty sure i’ve managed to replicate/copy the working settings over to audience.
I have Wan ISP on “ether1” upstream, Alt.Subnets 0.0.0.0/0. Downstream is “ether2”
Also added neccesary and maybe a few uneccesary IP adresses to firewall rules and added rules for IGMP and UDP identical as on the 750GL. But no go, i just cant seem to get iptv working.
Also ISP dosnt use VLAN’s for IPTV unless the changed something last two weeks.
Will be very happy if someone can help me getting this working XD
EXPORT config
# oct/26/2022 17:11:31 by RouterOS 6.49.7
# software id = 16WW-5DAP
# model = RBD25G-5HPacQD2HPnD
# serial number = HCX084DS60Y
add admin-mac=18:FD:74:6A:B1:B6 auto-mac=no comment=defconf igmp-snooping=yes \
    igmp-version=3 multicast-querier=yes multicast-router=permanent name=\
    bridge
/interface wireless
# managed by CAPsMAN
# channel: 2412/20-Ce/gn(16dBm), SSID: Hovvarpne2,4N, local forwarding
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
# channel: 5180/20-Ceee/ac/P(18dBm), SSID: Hovvarpne5AC, local forwarding
set [ find default-name=wlan2 ] disabled=no ssid=MikroTik
/caps-man security
add authentication-types=wpa2-psk comment=defconf name=capSec passphrase=\
/caps-man configuration
add channel.band=2ghz-b/g/n channel.control-channel-width=20mhz \
    channel.extension-channel=XX comment=defconf country=norway \
    datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes \
    distance=indoors installation=indoor name=cfg-2ghz security=capSec ssid=\
    Hovvarpne2,4N
add channel.band=5ghz-a/n/ac channel.control-channel-width=20mhz \
    channel.extension-channel=XXXX comment=defconf country=norway \
    distance=indoors installation=indoor name=cfg-5ghz-ac security=capSec \
    ssid=Hovvarpne5AC
add channel.band=5ghz-a/n channel.control-channel-width=20mhz \
    distance=indoors installation=indoor name=cfg-5ghz-an security=capSec \
    ssid=Hovvarpne5AC
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk comment=defconf disable-pmkid=yes mode=\
    dynamic-keys name=wpsSync supplicant-identity=MikroTik \
    wpa2-pre-shared-key=SorgalArt
/interface wireless
set [ find default-name=wlan3 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX \
    disabled=no mode=ap-bridge security-profile=wpsSync ssid=SYNC-6AB1B9
add name=dhcp ranges=192.168.88.100-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add comment=defconf disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled comment=defconf hw-supported-modes=gn \
    master-configuration=cfg-2ghz name-format=prefix-identity name-prefix=\
    2ghz
add action=create-dynamic-enabled comment=defconf hw-supported-modes=ac \
    master-configuration=cfg-5ghz-ac name-format=prefix-identity name-prefix=\
    5ghz-ac
add action=create-dynamic-enabled comment=defconf hw-supported-modes=an \
    master-configuration=cfg-5ghz-an name-format=prefix-identity name-prefix=\
    5ghz-an
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 enabled=yes interfaces=\
    wlan1,wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.238 mac-address=68:63:59:9A:6F:3C server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=\
    130.67.15.198,193.213.112.4 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=93.91.111.2 list="Telenor T-We"
add address=93.93.111.26 list="Telenor T-We"
add address=233.184.48.49 list="Telenor T-We"
add address=233.184.48.94 list="Telenor T-We"
add address=233.184.49.39 list="Telenor T-We"
add address=239.255.255.250 list="Telenor T-We"
add address=148.122.7.125 list="Telenor T-We"
add address=244.0.0.1 list="Telenor T-We"
add address=224.0.2.3 list="Telenor T-We"
add address=233.184.48.212 list="Telenor T-We"
add address=93.91.111.6 list="Telenor T-We"
add address=192.168.88.238 list="Telenor T-We"
add action=accept chain=input comment=::IPTV protocol=igmp src-address-list=\
    "Telenor T-We"
add action=accept chain=forward protocol=igmp src-address-list="Telenor T-We"
add action=accept chain=input protocol=udp src-address-list="Telenor T-We"
add action=accept chain=forward protocol=udp src-address-list="Telenor T-We"
    established,related,untracked
    invalid src-address-list="!Telenor T-We"
    ipsec-policy=in,ipsec src-address-list="!Telenor T-We"
    ipsec-policy=out,ipsec src-address-list="!Telenor T-We"
    connection-state=new in-interface-list=WAN src-address-list=\
    "!Telenor T-We"
    connection-state=invalid src-address-list="!Telenor T-We"
    in-interface-list=!LAN src-address-list="!Telenor T-We"
/ip service
set telnet disabled=yes
set ftp address=192.168.88.0/24
set www address=192.168.88.0/24
set ssh address=192.168.88.0/24
set api address=192.168.88.0/24
set winbox address=192.168.88.0/24
set api-ssl address=192.168.88.0/24
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 comment=::LAN interface=bridge threshold=3
add alternative-subnets=0.0.0.0/0 comment=::WAN interface=ether1 threshold=3 \
    upstream=yes
/system clock
set time-zone-name=Europe/Oslo
/system logging
add topics=igmp-proxy
add disabled=yes topics=debug
/tool mac-server
/tool mac-server mac-winbox
SOLVED
After upgrading to RouterOS 7.6 and setting Downstream interface to ‘bridge’ instead of ‘ether1’ Multicast traffic started working.
