The new IP range 202.78.170.x is using a vda2 disk partitioning system according to the df -h command
It shows me the following print.
Filesystem Size Used Avail Use% Mounted on
tmpfs 46M 968K 45M 3% /run
/dev/vda2 20G 2.9G 16G 16% /
tmpfs 230M 0 230M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 46M 12K 46M 1% /run/user/0
Normally the commands that I traditionally apply for the installation of versions 7.x are the following.
1- wget https://download.mikrotik.com/routeros/7.4/chr-7.4.img.zip
2- unzip chr-7.4.img.zip
3- dd if=chr-7.4.img of=/dev/sda
4- /ip address add address=202.78.170.x/24 interface=ether1
/ip route add gateway=202.78.170.1
When you restart the system it crashes, preventing the OS from loading.
How would step number 3 be modified for installation on a partition of type /dev/vda2 according to the df -h command, or equally if someone has already managed to mount it, share the lines with me, I would thank you.
