everything is fine and works perfectly, the only thing that bothers me and that when I go on websites such FORUM, BLOG, ticket system, I am always thrown out because of the quick change of IP load balancing.
how can I fix it? please help me use the connection to work.
You must increase you max UDP packet size. I recommend 4096. You will have truncated answers with 512. Also you will end up with DNS amplification attacks against your router if you have an open DNS. Either block UDP 53 from wan or limit it.
Connections are unidirectional so you don’t need to match them in and out. Also your marking all packets with connection marks. Either only mark with a state of new or that are not already marked.
I think these changes could help. Honestly there is a lot here that I don’t know the reason for but I think the big deal is that your re marking your connections.
well it seems that the problem is solved now but I do not understand why I can not put in the bridge Ether3 that is the one that has the ip with ether4 ether5, could you tell me the script to be taken pr to go with the bridge ether4 and ether5 number 3
hello, I’m sorry to say but this system did not work, he continues to throw me out of sites such as forums, blogs etc etc, it seems that the latency in changing the ip in load balancing, how can I solve it?
hello, I can not let go of this load balancing, basically I change the remote ip of continuous ip ip1 and quellodi ISP2 and causes me to fall free from the websites you forums, blogs etc etc, you could kindly tell me a solution? are also willing to let you remotely access my routerboard, if anyone can help me please, because I can not work.
Good evening to all, please help, I do not know why the configuration with load balancing everything works perfect, but I can not loggarm, on the forum, or makes me constantly logout, you could kindly tell me how can I solve this problem
This script assumes that you have 2 equal WAN connections(ex. two 7/1 DSL lines). If you have unbalanced connections you can modify the section of the script that defines how the traffic is balanced. That starts on line 6.
For example I have a 45/6 connection and a 30/6 connection and I have the following lines( Note that there are 5 lines and the first one starts at 5/0 and moves on from there):
The PCC method automatically does failover. All around good way to load balance 2 connections. You can also balance more connections by configuring the script correctly.
