Hi, that’s the first time in my life I figure this IPoE, I can’t find a valid documentation describing e how it works, I just read “it’s simple”, and for now it doesn’t look so.
The provider is giving me a private IP, I obtain it with DHCP client and it’s enough for access internet.
The provider gave me also a public IP, which I need to access devices there, it wrote that IP on paper, and wrote it’s truely natted to another private IP 100.200.236.41, with mask 255.255.252.0 and gateway 100.200.236.1, which I suppose I should use only.
As first attempt I simply added to router the IP 100.200.236.41/22 with network IP 100.200.236.0, but I can’t ping IP 100.200.236.1.. so I suppose I need a kind of authentication before. How? On this paper the provider doesn’t give me any user/password for it, I have them for the control panel, I might use them but where? Should I create on Mikrotik a PPPoE client session? And which is the server where I have to addess the authentication? Why the provider didn’t specife it?
This world sounds reallhy strange for me
Thanks for bright my ideas
