Help! NAT with dynamic IP...
Hi all,
Despite all my attempts I still cannot get NAT to work between my wired and wireless connections on my RB411. I have read the basic guide and the FAQ on natting, and I fully understand the concept, I just can’t seem to get it working. Here is my setup:
ether1 - DHCP client, receives a dynamic IP in the range 134.219.138.1/24
wlan1 - Bridge mode, DHCP server, assigns correctly from the pool 192.168.0.1/24, though I always get 192.168.0.254 for some reason, not 192.168.0.1…
My ether1 connection ended up with the address 134.219.138.77, so I set up the NAT rules (though they didn’t work), but what if my assigned ether1 IP changes? I doubt I would have to reconfigure NAT each time…
Can anyone turn my description of my situation into some NAT rules that will let me access the net from my wireless please?!
This should work for dynamic ip on ether1
add chain=srcnat action=masquerade out-interface=ether1
And wlan1 should be in ap-bridge mode if you want more than one client to connect.
If you are assigning 192.168.0.1/24 with dhcp, what ip did you assign to wlan1? I normally use 192.168.0.1 for the localnet gateway (wlan1 in this case), and my dhcp issues 192.168.0.4-192.168.0.254
I tried ap-bridge, but it said my license didn’t permit it, seems odd that I can buy an expensive bit of hardware that doesn’t do what a cheap commercial router can. Is there no setting to make it act like a wireless router? I think I have a level 4 license.
I tried that masquerade rule, but I think I may have given it the wrong interface, so I will try again.
Ok, still no joy, heres my config, maybe I'm missing something.
Interfaces:
[admin@MikroTik] > /interface print
Flags: X - disabled, R - running, D - dynamic, S - slave
NAME TYPE MTU
0 ether1 ether 1500
1 R wlan1 wlan 1500
IP Addresses:
[admin@MikroTik] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; Wlan Interface
192.168.0.1/24 192.168.0.0 192.168.0.255 wlan1
1 D 134.219.138.77/23 134.219.138.0 134.219.139.255 ether1
Routes:
[admin@MikroTik] > ip route print
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 ADC 134.219.138.0/23 134.219.138.77 0 ether1
1 ADC 192.168.0.0/24 192.168.0.1 0 wlan1
NAT:
[admin@MikroTik] > ip firewall nat print
0 chain=srcnat action=masquerade out-interface=ether1
According to that you don’t have a default route
make sure the DHCP client listening on ether1 has add-default-route set to yes. That is the default but didn’t seem to work in your configuration
The RB411 only comes with a Level 3 license which doesn’t support AP-Bridge mode. That takes a level 4 license. You can run Bridge mode with the level 3 license device which will only connect to a single wireless device at a time.
You can see the RouterBoard license with:
[admin@MikroTik] >/system license print
The RB411 is designed for wireless CPE not really as wireless router. At $49 it is not considered ‘expensive’ for Mikrotik.
Tom
I have since reset the whole configuration, and default routes were established, but I have a question. Should default routes point to the router or the public IP? Because I ran setup and it went to the public IP, I’m not sure that’s right..
For Mikrotik maybe not, but bear in mind that price is just the board. To make a fair comparison you have to add a case, wireless card and antenna. I paid just over 100GBP for mine, which is much more than the standard wireless routers for SOHO users, I just assumed I would be able to use it as an AP, which I imagine is the main reason people buy wireless hardware.
Anyway I digress. This thing still refuses to work, the wireless interface between my RB411 and my laptop works fine, hands out DHCP addresses and lets me login and configure the device. The wired interface between me and the campus DHCP server appears to work fine, it gets an address in the right subnet anyway. There is a single NAT rule, to masquerade all traffic on the srcnat chain on my wired connection. Still no joy.
I can post my config again if it helps, but essentially its the same as before, clearly whatever was wrong is still wrong.
Cheers
I think RB411 doesn’t support AP Bridge Mode. it should be RB433 for AP Bridge Mode
You need to set a default route to any ip addresses your router doesn’t know about.
add gateway=134.219.138.1
That should be the gateway for that network. If your ISP gave you a different one, use it.
Post the output of:
/ip firewall nat print
/ip dhcp-client print
/ip dhcp-server export
/ip pool print
/ip address print
/ip route print
/system routerboard print
That will be enough information to answer your questions
Ok, here is the config. For some reason my ether1 DHCP address is coming back on an odd subnet, I think it’s the network authentication server, but I still get nothing in my browser.
[admin@MikroTik] > /ip firewall nat print
[admin@MikroTik] >> /ip dhcp-client print
 #   INTERFACE                      USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS        ADDRESS
 0   ;;; added by setup
     ether1                         yes          yes               bound         10.0.33.169/22
[admin@MikroTik] >> /ip dhcp-server export
# jan/01/2000 00:21:04 by RouterOS 3.0
# software id = ####-###
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static disabled=no \
    interface=wlan1 lease-time=3d name="dhcp1"
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.0.0/24 comment="" gateway=192.168.0.1
[admin@MikroTik] >> /ip pool print
 # NAME                                                             RANGES
 0 dhcp_pool1                                                       192.168.0.2-192.168.0.254
[admin@MikroTik] >> /ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
     192.168.0.1/32     192.168.0.0     192.168.0.255   wlan1
 1 D 10.0.33.169/22     10.0.32.0       10.0.35.255     ether1
[admin@MikroTik] >> /ip route print
 #      DST-ADDRESS        PREF-SRC        GATEWAY-STATE GATEWAY         DISTANCE INTERFACE
 0   S  0.0.0.0/0                          unreachable   134.219.138.1   1
 1 ADS  0.0.0.0/0                          reachable     10.0.32.1       0        ether1
 2 ADC  10.0.32.0/22       10.0.33.169                                   0        ether1
 3 ADC  192.168.0.0/32     192.168.0.1                                   0        wlan1
[admin@MikroTik] >> /system routerboard print
       routerboard: yes
             model: "411"
     serial-number: "185F01FF7865"
  current-firmware: "2.12"
  upgrade-firmware: "2.12"
you are running 3.0? Upgrade to 3.30 and try again.
How can I upgrade with no internet??
If we assume that the DHCP server on the ether1 side of this router will provide DHCP services correctly AND that it provides a DNS server to your router, then this configuration looks like it should work. Your DHCP client (on your laptop or whatever) should be getting a dhcp assigned dns server address. Is that true?
Thats the plan, but just in case I was specifying Google’s public dns to be sure at one point, that didn’t work either.
Reconfiguring this thing is wearing thin… I might spoof my MAC address on my laptop, go authenticate with the network, then give it another shot.
you have access to this forum, i assume you have internet somewhere. just download the 3.30 packages, and then winbox them to your router (drag from your PC to files window in winbox). 3.0 is really buggy and could be part of your problem.
Sam
Ok, so an update on my continuing nightmare.
I tried to upgrade with the 3.30 combined package, over winbox the router disconnects after 31.5kb of upload, tried mutliple times with multiple re-downloads. Over FTP it doesnt allow me to connect even though 21 is open. I reset my configs, still no joy. I don’t have a serial interface, so it looks like i’m screwed right? I tried the upgrade over wired and wireless, and with the individual packages as well, no joy…
Ok, finally FTP played ball and I have 3.30 running, but little has changed. I still have no access, and I still get this mystery 10.x.x.x address assigned to ether1, so I will investigate.
your wlan address is wrong:
Delete that, and add 192.168.0.1/24. Leave the network and broadcast fields blank and hit apply. It looks like there was a /24 and then it was changed to /32.
To test things, do a traceroute right from the router. “/tool traceroute 204.16.170.40”
Sam
Still no love with this, is there a way to tell the dhcp client which server you want it to use? Aside from this I really dont see anything wrong with the config.
