HELP Needed on how to Port forward
Hi
I’m a newbie and I am facing an issue in port forwarding.
I would like help on how to port forward from multiple LAN networks in MikroTik up to ISP CPE. Following is the scenario.
My NVR: 192.168.4.14:7443
The NVR is connected to Mikrotik Switch (CRS125-24g-1s-2hnd): 192.168.4.0 network
The Mikrotik switch(CRS125-24g-1s-2hnd) is connected to a connected Mikrotik router (RB2011uias-2hnd-in): 192.168.88.0 network
The Mikrotik router( RB2011uias-2hnd-in) is connected to ISP CPE ONT router (ZNID-GPON-2426A-UK) provided by ISP: 192.168.1.0 network
Not enough info. First, you need to have public address somewhere. Assuming it’s on ISP CPE, first you need to forward port from there. Where to depends on how the rest of the network is configured. If there are routes between all subnets on all routers, you can forward it directly to 182.168.4.14. If not, you may need to do it step by step, first forward the port from ISP CPE to 192.168.1.10, then on RB2011 and another port forwarding rule to 192.168.88.1, and finally on CRS the last port forward to 192.168.4.14.
