Hi, I’m quite new in setup Mikrotik devices here is my setup.
model: CRS328-24P-4S+
current-firmware: 7.9
I’ve also a ‘cAP ax’ but it’s not the point here.
I’m looking for a documentation on how to implement vlan on bridge with filtering on .
Bellow a diagram of what I did :
For general environnement, my switch router name ‘SwRo’ is directly connected to the ONT of my internet provider (no internet box anymore).
/interface vlan add interface=sfp1 name=ONT-Bouygue-Fibre vlan-id=100
/ip dhcp-client option add code=60 name=vendorid value=0x42594754454c494144
/ip dhcp-client add dhcp-options=vendorid disabled=no interface=Fibre_ByTel_vl100
/interface bridge port add bridge=bridge interface=ether1
/interface bridge port add bridge=bridge interface=ether24
/interface bridge port add bridge=bridge interface=sfp-sfpplus1
/interface bridge port add bridge=bridge interface=sfp-sfpplus3
/interface bridge port add bridge=bridge interface=sfp-sfpplus4
/ip firewall nat add action=masquerade chain=srcnat out-interface=ONT-Bouygue-Fibre
/ip address add address=192.168.0.2/24 comment=LAN_HOME interface=bridge network=192.168.0.0
/ip address add address=192.168.0.88/24 comment=defconf interface=ether2 network=192.168.0.0
All above works as attended.
Next I setup a Trunk port with 2 tagged vlan.
I did my setup following this guide : http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
post #2 : Switch with a separate router (RoaS) : section Router Configuration at a glance.
add frame-types=admit-only-vlan-tagged name=bridge-v vlan-filtering=no
/interface vlan
add interface=bridge-v name=VLAN2 vlan-id=2
add interface=bridge-v name=VLAN5 vlan-id=5
/interface bridge vlan
add bridge=bridge-v tagged=sfp-sfpplus2 vlan-ids=2,5
add interface=VLAN2 list=VLAN
add interface=VLAN5 list=VLAN
add address=192.168.2.1/24 interface=VLAN2 network=192.168.2.0
add address=192.168.5.1/24 interface=VLAN5 network=192.168.5.0
On the other side I plug a FreeBSD host with Jail on Vlan. All seems to work I can ping internet or anyone in my lan from booth Vlan.
What I wanted is to isolate VLAN2 and VLAN5 of anyone else. But they need to be able to go to internet.
For this I had to change on bridge-v vlan-filtering to yes.
But when I did this on booth vlan I can’t even ping there gateway (192.168.2.1 / 192.168.5.1).
I think I add to add some rules in : /interface/bridge/nat and /interface/bridge/filter/ .
I’m looking for documentation about bridge vlan filtering.
