Help Please
I’m a beginner in Mikrotik routers, I know how to connect 2 antennas, but i’m trying to do that now but i’m facing this problem:
when i try to connect to my ssid, once i press “Connect” i got this message in the status field:“disabled”, then “Searching for Network”, after that my ssid disappear for a time, sometimes until i redirect the antennas, which is frustrating.
distance between antennas is around 4 km, nv2 protocol, one antennas is configured as PTP AP, the other antenna is PTP CE, signal is around -75dB
noting that when first worked on them, the antenna connected very well with bandwidth around 20Mb, but that was a year ago, one antenna (the one configured as PTP AP) got damaged and replaced, now the problem appeared.
