Hi all,
I’m very new to networking and I’m playing around as a hobby.
I recently got a raspberry pi and I loaded PiVPN (an install of OpenVPN) onto it. I’m trying to connect to the VPN from my home laptop through my Mikrotik router. In other words, both the raspberry pi running OpenVPN and the laptop are connected to the router and the router is connected to the internet. Unfortunately, I’m not able to connect to the VPN on the raspberry pi, I keep getting timed out. I have no trouble accessing the internet through the router, and I’ve been able to successfully install PiHole (a DNS ad blocking software) on my raspberry pi.
Here is my firewall filter export:
add action=accept chain=forward dst-address=192.168.88.250 dst-port=11913 in-interface=ether1 protocol=udp
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
This is the default firewall filter that came with router.
I’ve tried to do this with the NAT:
add action=dst-nat chain=dstnat dst-address=<public-IP> dst-port=1194 protocol=udp to-addresses=<internal-RaspberryPi-IP> to-ports=1194
This doesn’t work. Where am I going wrong?
Thanks for your time and help!
