HELP ROUTERS HELP HELP HELPP
Necessary to make with that traffic on network 200.100.200.176/29 you the 200.100.200.169/29 that it is one another net, that this in my to router CISCO.
Necessary to make with that traffic on network 200.150.140.0/26 you the 200.100.200.169/29 that and ’ my to router CISCO.
Should basically work, as all the IP addresses and the corresponding netmasks etc. are looking good.
So what exactly is the problem, what is working right now and what isn’t?
Please post the output of
/interface print
/ip addr print
/ip route print
from your MT, and traceroute output from the computers connected to the switches, and maybe netstat -nr of the computers.
–Tom
/interface print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R vlan02 ether 0 0 1500
1 R vlan03 ether 0 0 1500
2 R router ether 0 0 1500
[admin@MikroTik] interface>
/ip addr print
[admin@MikroTik] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 200.100.200.177/29 200.100.200.176 200.100.200.183 vlan02
1 200.100.200.170/29 200.100.200.168 200.100.200.175 router
2 200.150.140.14/26 200.150.140.0 200.150.140.63 vlan03
/ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, r - rip, o - ospf, b - bgp
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r 200.100.200.169 1 router
1 DC 200.100.200.176/29 r 0.0.0.0 0 vlan02
2 DC 200.100.200.168/29 r 0.0.0.0 0 router
3 DC 200.150.140.0/26 r 0.0.0.0 0 vlan03
[admin@MikroTik] ip route>
Do you want to run vlan02 and vlan03 as VLAN (as per 802.1q) interfaces, or are these supposed to be plain ethernet interfaces? Just asking because of the name vlanXX… anyway, it’s just a name.
Other than that, it basically looks OK. You still did not describe what currently works and what does not work?
Can you /ping from the MT to the Cisco? From the computers in both networks to the corresponding IP address of the MT? From both computers to the Cisco?
If you can ping from MT to Cisco, and from the computers to the MT but not to the Cisco, then check that the Cisco has a correct route back into both your computer networks (via the MT as gateway) in addition to the default route on the SDSL uplink.
–Tom
well of the MIKROTIK works ok saw the interface "to router" with the IP adress 200.100.200.170/29, ping for
200.100.200.169/29 (ROUTER Cisco) has success.
[admin@MikroTik] > ping http://www.mikrotik.com
159.148.147.196 64 byte ping: ttl=37 time=100 ms
159.148.147.196 64 byte ping: ttl=37 time=121 ms
159.148.147.196 64 byte ping: ttl=37 time=118 ms
159.148.147.196 64 byte ping: ttl=37 time=130 ms
159.148.147.196 64 byte ping: ttl=37 time=200 ms
"ipconfig on station"
Ethernet adaptador Real:
Sufixo DNS específico de conexão . :
Endereço IP. . . . . . . . . . . . : 200.100.200.178 IP ADRESSS
Máscara de sub-rede. . . . . . . . : 255.255.255.248 MASK
Gateway padrão . . . . . . . . . . : 200.100.200.177 GATEWAY
"netstat -nr on station"
Rotas ativas:
Endereço de rede Máscara Ender. gateway Interface Custo
0.0.0.0 0.0.0.0 200.100.200.177 200.100.200.178 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
200.100.200.176 255.255.255.248 200.100.200.178 200.100.200.178 1
200.100.200.178 255.255.255.255 127.0.0.1 127.0.0.1 1
200.100.200.255 255.255.255.255 200.100.200.178 200.100.200.178 1
224.0.0.0 224.0.0.0 200.100.200.178 200.100.200.178 1
255.255.255.255 255.255.255.255 200.100.200.178 200.100.200.178 1
Gateway padrão: 200.172.74.177
Rotas persistentes:
Nenhuma
C:\Documents and Settings\Administrador>
"ping to 200.100.200.177 sucess"
Disparando contra 200.100.200.177 com 32 bytes de dados:
Resposta de 200.100.200.177: bytes=32 tempo<10ms TTL=64
Estatísticas do Ping para 200.100.200.177:
Pacotes: Enviados = 4, Recebidos = 4, Perdidos = 0 (0% de perda),
Tempos aproximados de ida e volta em milissegundos:
Mínimo = 0ms, Máximo = 0ms, Média = 0ms
"ping to 200.100.200.169 (CISCO ROUTER) no respond"
Disparando contra 200.100.200.169 com 32 bytes de dados:
Esgotado o tempo limite do pedido.
Estatísticas do Ping para 200.100.200.169:
Pacotes: Enviados = 4, Recebidos = 0, Perdidos = 4 (100% de perda),
As written previously, please check the routing table of the Cisco and make sure that
it has a correct route to both networks behind the MikroTik router.
The information you gave strongly suggests that the problem is to be found there.
Also, make sure that you do not have firewall rules on the MikroTik router that would block the forwarding.
–Tom
well my doubts and this exactly forward in the MIKROTIK, I no knows to make knows that it needs, As make this? The problem this in roteament in the MIKROTIK, because I I ping successfully in the MIKROTIK to put in Cisco ROUTER no. If I to drip in Cisco ROUTER I am in the InterNet.
you knows to make forward in the MIKROTIK, necessary to give one forward in the packages of a net for the other. It can give an example to me of as I make this?
