I am pretty sure I am doing something wrong. This is essentially my first time setting up IPv6 and I am still wrapping my head around some of the concepts that are different from IPv4.
I have seen my AP router (rbr50) showing address and prefix on br0 as a valid global /64, so I assume I should be able to work with what the ISP provides. Also when configuring the hex s as a switch, all connected devices are getting valid global v6s
I managed to get someone from my ISP's “tech support” team to call me back and claim (they did not seem very knowledgeable) that “prefix delivery” is not supported.
I was pivoting and trying to get a working SLAAC setup, like so:
/ipv6 settings
set accept-router-advertisements=yes
this should have enabled clients to receive RAs and configure a valid global address with the right prefix.
I got to a weird state (that I could not reproduce in later attempts) where I eventually got clients to have valid GUAs within the prefix provided by ISP RAs.
However routing still failed, tho DNS resolution seemed to work for some odd reason.
I finally managed to get a working IPv6 setup using “NAT66”. Basically adding a ULA prefix pool, assigning ::1/64 from the pool as an address to bridge and setting up a masquerade rule from ULA prefix pool to ether1 (wan).
the downside seems to be that there is a ~6ms routing lag introduced for IPv6 vs IPv4 now.
