HELP WITH IDLE TIMEOUT IN HOTSPOT
I am having some problems with my hotspot clients.
They were all connecting and working but within 2 -3mins, their connection will log them out and display the login page again. This situation has been distrubing as they cant do anything thru the hotspot.
Here is my hospot details
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
add dns-name=hotspot.timasybankrd.net hotspot-address=172.16.0.1
html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap name=
hsprof1 nas-port-type=wireless-802.11 radius-accounting=yes
radius-default-domain=“” radius-interim-update=received
radius-location-id=“” radius-location-name=“” radius-mac-format=
XX:XX:XX:XX:XX:XX rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=yes
/ip hotspot
add address-pool=dhcp_pool1 addresses-per-mac=1 disabled=no idle-timeout=50m
interface=ether1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip hotspot ip-binding
add address=192.168.10.230 comment=“” disabled=no type=bypassed
add address=172.16.0.230 comment=“” disabled=no server=hotspot1 type=bypassed
add address=172.16.0.5 comment=“” disabled=no server=hotspot1 type=bypassed
add address=172.16.0.6 comment=“” disabled=no server=hotspot1 type=bypassed
add address=172.16.0.7 comment=“” disabled=no server=hotspot1 type=bypassed
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add comment=“” disabled=no name=dede password=dd profile=default
server=hotspot1
add comment=“” disabled=no name=panda password=divine profile=default
plz your help will be appreciated. I am running RouterOS 3.22
what’s in Log?
have you checked 3.30/4.1 versions?
here is my log
[admin@Installer] /log> pr
06:57:57 system,error,critical router was rebooted without proper shutdown
06:58:02 dhcp,info dhcp1 assigned 172.16.0.12 to 00:23:8B:81:3D:58
06:59:07 hotspot,info,debug naphtali (172.16.0.11): trying to log in by http-chap
06:59:07 hotspot,account,info,debug naphtali (172.16.0.11): logged in
07:57:34 dhcp,info dhcp1 assigned 172.16.0.14 to 00:1D:D9:29:0E:54
08:53:02 hotspot,info,debug universal (172.16.0.30): trying to log in by http-chap
08:53:02 hotspot,account,info,debug universal (172.16.0.30): logged in
09:00:03 dhcp,info dhcp1 deassigned 172.16.0.19 from 00:21:29:81:7D:33
09:00:03 dhcp,info dhcp1 assigned 172.16.0.19 to 00:21:29:81:7D:33
09:04:31 hotspot,info,debug chazz (172.16.0.24): trying to log in by http-chap
09:04:31 hotspot,account,info,debug chazz (172.16.0.24): logged in
09:18:59 hotspot,info,debug naphtali (172.16.0.11): logged out: keepalive timeout
09:21:22 hotspot,info,debug universal (172.16.0.30): logged out: keepalive timeout
09:30:33 hotspot,info,debug universal (172.16.0.30): trying to log in by http-chap
09:30:33 hotspot,account,info,debug universal (172.16.0.30): logged in
09:32:44 hotspot,info,debug universal (172.16.0.30): logged out: keepalive timeout
09:35:28 hotspot,info,debug naphtali (172.16.0.11): trying to log in by http-chap
09:35:28 hotspot,account,info,debug naphtali (172.16.0.11): logged in
09:38:20 hotspot,info,debug universal (172.16.0.30): trying to log in by http-chap
you may try to increase keepalive-timeout value - it’s defaut value is exactly 2m, afair
thanks,
But I am not using the default, unless if someone did not specify the keep alive timeout value, it takes the default value. I have tried doing that but wil monitor it and give you feedback.
I believe you need to take a look at the User Profiles, if you are just using the default profile the Keepalive Timeout is also set in there as well.
Cookies!..
Activate cokies “login by” in the Server profiles section, the keepalive and idle is better in 0.
Bonsoir Avez vous trouvé la solution a votre hotspot qui s'affichait simultanément apres un certain nombre de temps sans que la session ne soit arrivée a terme?
