Help with VLan and multiple SSID
Hello everyone, thanks for reading.
I have the following setup:
Mkt 951G-2HnD: Ethernet-2 <-------> UNIFI AP A
Ethernet-3 <-------> UNIFI AP B
Each UNIFI has 4 SSID. Lets suppose SSID1, SSID2, SSID3, SSID4. Each one referred to a Vlan, let suppose Vlan1, Vlan2, Vlan3, Vlan4 respectively.
What I want to achieve is to set Ethernet-2 and Ethernet-3 in the MKT as trunk ports and to join in a bridge (or however its done) Vlan from UNIFI AP A with Vlan 1 from UNIFI AP B, and so on with the remaining vlans.
Then I want to add a DHCP server to each Vlan but I know how to do that, I am just needing help to achieve the structure defined above .
I would appreciate very much any kind of help!
Thanks!
Gonzalo
Can anyone give me a little hand with this.
Thanks.
GN
It’s pretty easy to achieve. If you want some help about that, it would be pretty easier for people reading your post, if you could draw it with something like gliffy (it’s free and online).
Put your vlan, dhcp, everything on it, it’s more visual. I’ll see if i can help you after looking at your diagram.
Andy
