This is my first time configuring Mikrotik.
I have a 4011 router and a CSR326 switch. I have tried to configure the VLANs as outlined in this http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1 but with limited success.
I have 4 Vlans on the switch, and I’m using SFP-SFPPLUS1 as the trunk between the switch and the router. Port 10 on the router is a MGMT port.
From VLAN Secure (10.6.10.0), on the CSR326 I can ping other hosts on that segment, but I can’t ping the gateway (10.6.10.1)
If I’m on VLAN MGMT, (port 10 on the router) I can ping Google and basically everything works from there.
I have included both the config from the router and the switch since I have no idea what is wrong.
If there is anything else required to help point me in the right direction, I’'l get it.
Thanks.
mar/06/2019 15:11:44 by RouterOS 6.44
# software id = 2Z41-IHGR
# model = RB4011iGS+
add frame-types=admit-only-vlan-tagged name=Bridge1 protocol-mode=none \
vlan-filtering=yes
/interface vlan
add interface=Bridge1 name=Guest_VLAN vlan-id=30
add interface=Bridge1 name=IoT_VLAN vlan-id=20
add interface=Bridge1 name=MGMT_VLAN vlan-id=99
add interface=Bridge1 name=Secure_VLAN vlan-id=10
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=WAN
add name=LAN
add name=VLAN
add name=Secure_POOL ranges=10.6.10.200-10.6.10.254
add name=IoT_POOL ranges=10.7.20.200-10.7.20.254
add name=Guest_POOL ranges=10.6.30.150-10.6.30.254
add address-pool=Secure_POOL disabled=no interface=Secure_VLAN name=\
Secure_DHCP
add address-pool=IoT_POOL disabled=no interface=IoT_VLAN name=IoT_DHCP
add address-pool=Guest_POOL disabled=no interface=Guest_VLAN name=Guest_DHCP
add bridge=Bridge1 frame-types=admit-only-vlan-tagged ingress-filtering=yes \
interface=ether2
interface=ether3
interface=ether4
interface=ether5
interface=ether6
interface=ether7
interface=ether8
interface=ether9
add bridge=Bridge1 frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=ether10 pvid=99
interface=sfp-sfpplus1
set discover-interface-list=none
/interface bridge vlan
add bridge=Bridge1 tagged="Bridge1,ether2,ether3,ether4,ether5,ether6,ether7,e\
ther8,ether9,ether10,sfp-sfpplus1" vlan-ids=10
ther8,ether9,ether10,sfp-sfpplus1" vlan-ids=20
ther8,ether9,ether10,sfp-sfpplus1" vlan-ids=30
add bridge=Bridge1 tagged=Bridge1,sfp-sfpplus1 untagged=ether10 vlan-ids=99
add interface=ether1 list=WAN
add interface=MGMT_VLAN list=VLAN
add interface=Secure_VLAN list=VLAN
add interface=IoT_VLAN list=VLAN
add interface=Guest_VLAN list=VLAN
add address=192.168.0.1/24 interface=MGMT_VLAN network=192.168.0.0
add address=192.168.44.6/24 comment="WAN connection to Router" \
interface=ether1 network=192.168.44.0
add address=10.6.10.1/24 interface=Secure_VLAN network=10.6.10.0
add address=10.7.20.1/24 interface=IoT_VLAN network=10.7.20.0
add address=10.6.30.1/24 interface=Guest_VLAN network=10.6.30.0
add address=10.6.10.0/24 dns-server=192.168.0.1 gateway=10.6.10.1
add address=10.6.30.0/24 dns-server=192.168.0.1 gateway=10.6.30.1
add address=10.7.20.0/24 dns-server=192.168.0.1 gateway=10.7.20.1
set allow-remote-requests=yes servers=8.8.8.8
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" \
add distance=1 gateway=192.168.2.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.3/32
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/Toronto
/system identity
set name=William
/tool bandwidth-server
set enabled=no
/tool mac-server
Switch Config:
# jan/03/1970 00:06:44 by RouterOS 6.44
# software id = P6LR-WCGK
# model = CRS326-24G-2S+
add name=Bridge1 protocol-mode=none vlan-filtering=yes
/interface vlan
add comment=MGMT_VLAN interface=Bridge1 name=MGMT_VLAN vlan-id=99
/ip hotspot profile
ingress-filtering=yes interface=ether1 pvid=10
ingress-filtering=yes interface=ether2 pvid=10
ingress-filtering=yes interface=ether3 pvid=10
ingress-filtering=yes interface=ether4 pvid=10
ingress-filtering=yes interface=ether5 pvid=10
ingress-filtering=yes interface=ether6 pvid=10
ingress-filtering=yes interface=ether7 pvid=10
ingress-filtering=yes interface=ether8 pvid=10
ingress-filtering=yes interface=ether9 pvid=10
ingress-filtering=yes interface=ether10 pvid=10
ingress-filtering=yes interface=ether11 pvid=10
ingress-filtering=yes interface=ether12 pvid=10
ingress-filtering=yes interface=ether13 pvid=10
ingress-filtering=yes interface=ether14 pvid=10
ingress-filtering=yes interface=ether15 pvid=10
ingress-filtering=yes interface=ether16 pvid=10
ingress-filtering=yes interface=ether17 pvid=20
ingress-filtering=yes interface=ether18 pvid=20
ingress-filtering=yes interface=ether19 pvid=20
ingress-filtering=yes interface=ether20 pvid=20
ingress-filtering=yes interface=ether21 pvid=30
ingress-filtering=yes interface=ether22 pvid=30
ingress-filtering=yes interface=ether23 pvid=30
ingress-filtering=yes interface=ether24 pvid=30
add bridge=Bridge1 frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
add bridge=Bridge1 tagged=sfp-sfpplus1 untagged="ether1,ether2,ether3,ether4,e\
ther5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,\
ether15,ether16" vlan-ids=10
add bridge=Bridge1 tagged=sfp-sfpplus1 untagged=\
ether17,ether18,ether19,ether20 vlan-ids=20
ether21,ether22,ether23,ether24 vlan-ids=30
add bridge=Bridge1 tagged=Bridge1,sfp-sfpplus1 vlan-ids=99
add address=192.168.0.2/24 interface=MGMT_VLAN network=192.168.0.0
/ip service
/system identity
set name=Quagmire
/system routerboard settings
set boot-os=router-os
