hi
I wanted chierervi if it is possible to personalize the initial scrita mikrotik when digito the default gateway of the router.
regards
hi
regards
hi,
I wanted to ask you if personalizare is possible the home page of the routeros mikrotik when digiti the default gateway.
regards
Daniele
it is not possible to customize the RouterOS webpage
You could however “mis-use” the HotSpot feature for the purpose (though I’ve never tried that): Configure HotSpot to run on port 80, and create a “login” page which doesn’t really contain an login form - there you go.
But as I said: Just a thought, not tested in any way… ![]()
