help!
I’m fairly new to this.I’ve got a RB750GL & would like to setup a connection to my adsl router,will anybody help.I’ve tried youtube,but only get other language tutorials for beginners.
Using the GUI tool or web interface
. User admin password is blank
. System / (s)NTP Client
Enable Unicast
. System / Clock
. System Identity … give it a name
. IP / DNS / Settings / Allow remote requests (clients on the inside use you as a caching DNS)
. IP / Addresses
Add ether1 for WAN static IP provided by your ISP (unless you’re a DHCP client)
Add ether2 for LAN static IP
. IP / DHCP Client if you don’t have a static IP from your ISP
. IP / Routes - to add the default gateway provided by ISP (unless you’re a DHCP client)
Destination = 0.0.0.0/0 (any)
Gateway = provided by ISP
Interface = ether1 (added automatically on save?)
. IP / firewall / NAT
General tab
Chain = srcnat
Action tab = masquerade
. IP / DHCP Server
Click DHCP Setup
DHCP Server Interface = ether2
next, next, etc
If you have wireless:
. Wireless
Edit default entry then Wireless Tab
Mode = ap bridge (station to connect to another AP)
band = 2.4GHz-G or BG
. IP / Services
Turn off what you don’t need
. Tools / BTest Server
Click BTest Server Settings
Disable
. IP / Neighbors
Disable
. System / Password
Change the default password from blank to something
