I have RB750Gr3 HEX running as router and capsman + multiple RB952Ui-5ac2nD hAP AC lite as CAP with multiple wifi networks (SSID home, guest, iot).
I have different bridges for different ssid, so each of them gets different IP and I can do filtering etc (with local forwarding disabled) and this all is working fine.
Now I need to connect another tplink AP (bridged mode) to create just SSID “iot” (because my Goodwe inverter is still disconnecting from mikrotik wifi devices, tplink, dlink no problem) and connect it to one port (for example ethernet2) of one of hAP ACs, but I want it to act as it was created with capsman, so that clients gets correct IP etc
I think I could use VLAN for this - so that data received at ethernet2 port in hAP AC ends up at bridge “iot” in HEX and vice versa (data from bridge “iot” also ends up at ethernet2 of hAP AC)
Can you help me how to do it? Or is there another way for this?
Thanks.
