hEX - missing usb hub support
I plan to use Mikrotik for out-band management and remote console server.
So I purchased 7-ports usb hub and numbers of Prolific PL2303 usb-to-rs232 console cables.
I succesfully tested with RB951G - all 7 console lines appeared and worked with remote access.
But when I plug hub to hEX (RB750g3) - only 1 console line appeared instead 7.
I noticed that on on hEX router EHCI and OHCI controllers are missing, maybe its a reason.
[admin@RB951G] > driver print
 # DRIVER
 0 USB EHCI Controller
 1 USB OHCI Controller
 2 USB Prolific PL2303 Serial
[admin@RB951G] > port print
Flags: I - inactive
 #   DEVICE NAME                 CHANNELS USED-BY               BAUD-RATE
 0   1-1.1  usb1                        1 Serial Console        115200
 1   1-1.2  usb2                        1 Serial Console        115200
 2   1-1.3  usb3                        1 Serial Console        115200
 3   1-1.4  usb4                        1 Serial Console        115200
 4   1-1.5  usb5                        1 Serial Console        115200
 5   1-1.6  usb6                        1 Serial Console        115200
 6   1-1.7  usb7                        1 Serial Console        115200
[admin@RB750g3] > driver print
 # DRIVER
 0 USB Prolific PL2303 Serial
[admin@RB750g3] > port print
Flags: I - inactive
Is it possible to make hEX work with hub and multiple usb consoles?
Isn’t there lack of power? Try externally powered USB hub.
Yes, my hub is active with external power, its doesn’t metter
I checked some another routers, in summary:
  • CCR1016-12G, v6.40.4 - OK
  • CCR1009-7G-1C-1S+, v6.41.2 - OK
  • RB951G, v6.41.3 - OK
  • RB750G3, v6.41.2, v6.41.3 - problem exists
For anyone who consider to use hEX with multiple usb devices,
I contacted to support and after deep inspect the problem received next info:
Unfortunately, we are still investigating it and there is a possibility that this issue is due to hardware limitations and will not be fixed by software updates.
Thank you very much for the report and your careful research!
Do you or anyone else happen to know if the new hAP ac² (RBD52G-5HacD2HnD-TC (International), RBD52G-5HacD2HnD-TC-US (USA)) would also have similar issues with USB controllers?
Received and tested today - there is no such issue with new hAP ac², all 7 consoles appeared.
Yep. But hap ac2 has another big problem… The WiFi.
