hEX PoE (RB960PGS) Problem after 6.49.4 > 7.1.3 with SFP S-3553LC20D
Hello!
We have a hEX PoE (RB960PGS) with 6.49.4 (+ Firmware) running with a pair of S-3553LC20D - other side is RB3011UiAS. Both sides up, both sides show all values … running well without any problems.
Then we ran the Update on both sides. RB3011UiAS is ok with 1310.00 nm. But RB960PGS has
(1) no values
[admin@MikroTik] > /interface ethernet monitor sfp1
status: link-ok
auto-negotiation: done
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-type: (unknown)
eeprom-checksum: good
eeprom: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … …
(2) the Link is up, bit toggels from time to time.
Is S-3553LC20D not completely compatible with 7.1.3 - no tested jet but RouterOS is stable ?
Flash File Space is 24% used (what ever is on it, not shown) and the rest of 16 Mbit is not enought to step back to 6.49.4 - location is not on our side … How can we solve?
Please help,
Grüße Stefan
No idea about SFP module misbehaviour.
Re downgrade: it should be possible to downgrade ROS following this procedure:
  1. copy appropriate .npk file (e.g. routeros-mipsbe-6.49.4.npk) to files section.
    Make sure you don’t push it to flash/ directory, leave it in root directory. On devices with small flash disk, but decent RAM size, root of file storage is actually RAM disk
  2. execute /system/package/downgrade
  3. reboot device
Essentially follow the instructions for downgrading ROS … the essential thing is to leave npk file in root of file storage (i.e. in RAM disk).
Hello!
We will try to roll back. I’ll give you a feed back about it …
To Mikrotik Bug Report:
We have rebuilt the setup in our lab.
This behaviour is everytime the same on different Harwdare: SFP S-3553LC20D is not working with 7.1.3 !
Grüße Stefan
Rollback done.
SFP S-3553LC20D works NOT on 7.1.3 with
exemplary:
960PGS
CRS112-8P-4S
but with 6.49.4 again !
Grüße Stefan
