HEX Refresh Slow HW Offloading
I noticed others having issues with it being slow using ETH1 as WAN. If you disable HW offloading on the bridge ports then performance immediately improves
(near gigabit performance vs 250…). Anyone else tried that? It is counter-intuitive. Any bridge feature that causes hw offload to disable has a similar, positive impact.
Which ROS version?
7.17 and 7.18 both exhibit this behavior. I had the older HEX prior to it without the issue. I’m sure it is because ETH1 is a different switch from the other ports (using it for WAN), but you’d think hw offloading 2-5 wouldn’t hurt performance like it is. It is true if I use another port for WAN it is faster w/hw offload enabled, but MT obviously want people to use ETH1 for WAN given that is printed on it :slight_smile:
Do you have IGMP Snooping or DHCP Snooping enabled on the bridge?
I have them off but turning either or both on disables HW offload so turning them on has the same positive impact.
