I am considering using several of these routers, powered via their PoE ports with a 48V power supply.
I can also provide backup power to each router via its DC jack port at 12V.
I would like to know what happens if the PoE power supply fails. Will the router automatically switch to the 12V power supplied through the DC jack port?
If it does, will this switch cause the device to reboot, or will the transition between power sources be seamless, without affecting its operation?
Furthermore, once the PoE power supply is restored, will the router automatically switch back to the higher-voltage PoE power source?
That way ("main" via PoE, backup via jack) should work just fine if passive[1] PoE is used.
Generally speaking power lines (jack, 2-pin terminal(where available) and PoE) are all connected together with a simple diode protection.
The highest voltage of the three (two in your case) sources will be the one used normally.
Since you are using 48V or so from PoE, it will prevail but since you also power it via jack (why at 12V, you are not using the standard 24V power brick?) the moment PoE voltage goes out the power used will shift to the 12V gracefully.
And when you re-supply the 48V it should shift back to it as well gracefully.
But that applies for sure only if "passive" PoE is used.
If active PoE (802.3af/at) is used or the power source, even if "passive" uses some sensing procedure, it must be tested when the negotiation/sensing happens.
(it is entirely possible that the negotiation happens even if the power is drawn by the jack, but it is also possible that it is done - or repeated - when the power from the jack is cut off), see: Redundant power supply for CRS326-24G-2S+RM ? - #3 by mkx
My idea is to use PoE as the primary power source. I also have solar chargers with a 12V output that can provide power for approximately one hour. That's why I was asking about supplying 12V power through the DC jack.
Good, so the only variable is which exact kind of PoE source you will be using.
You can also use pure passive 24V with RBGPOE (reusing the provided power supply).
What @jaclaz wrote is accurate to the best of my knowledge.
I usually do things differently. If poe doesn't have some inherent advantage, I prefer using only the dc jack, and combine the two voltages externally with two diodes in a common cathode configuration.
A common part for this is the 1n4007, or if you want to be fancy, sr310. If you don't want to solder, it's totally fine to just use a screw-type terminal block used for electrical work.
Btw, the device runs fine on the usual lead acid voltages (10.5 - 13.8V)
