That is very similar to what I am doing. I am using my routers (RB750r2 & RB750Gr3) exclusively as routers. The different LAN ports connect to managed switches that handle ALL switching function. I don’t know if you will have any downstream switches, or will each port be connected to a single dedicated device, but as far as the router is concerned, it does not really matter. First of all, since no two LAN ports will normally communicate with each other, you do not need a bridge at all. In my case, I am using a combination of LAN subnets that have a physical port on the router and VLANs that come off the router as a VLAN trunk. Here is a piece of my config that should get you started.
set [ find default-name=ether1 ] comment="Spectrum cable internet" name=\
E1-p2_Cable_Internet speed=100Mbps
set [ find default-name=ether2 ] comment="Main cable home LAN" name=E2-p4_101 \
speed=100Mbps
set [ find default-name=ether3 ] comment="Cable Private WiFi" name=E3-p6_103 \
speed=100Mbps
set [ find default-name=ether4 ] comment="802.1Q trunk" name=E4-p8_802.1Q \
speed=100Mbps
set [ find default-name=ether5 ] comment="Router to Router tie" name=\
"E5 to Router 2" speed=100Mbps
/interface vlan
add comment="AREDN WAN" interface=E4-p8_802.1Q name=VLAN_001 vlan-id=1
add comment="AREDN LAN" interface=E4-p8_802.1Q name=VLAN_005 vlan-id=5
add comment="AREDN 3GHz at Johnstone to Pleasants Peak LAN interface" \
interface=E4-p8_802.1Q name=VLAN_011 vlan-id=11
add comment="AREDN 5GHz at Johnstone SW sector LAN interface" interface=\
E4-p8_802.1Q name=VLAN_012 vlan-id=12
add comment="AREDN 5GHz at Johnstone SE sector LAN interface" interface=\
E4-p8_802.1Q name=VLAN_013 vlan-id=13
add comment="AREDN Internal LAN" interface=E4-p8_802.1Q name=VLAN_015 \
vlan-id=15
add comment="Cable Public WiFi" interface=E4-p8_802.1Q name=VLAN_102 vlan-id=\
102
add comment="Cactus" interface=E4-p8_802.1Q name=VLAN_104 vlan-id=\
104
add comment="Scanner feed" interface=E4-p8_802.1Q name=VLAN_105 vlan-id=105
add comment="Internet of Things" interface=E4-p8_802.1Q name=VLAN_106 vlan-id=106
Looking first at the five physical Ethernet of the router, port 1 is my cable internet connection. Ports 2 & 3 are my normal home LAN and my private WiFi. Port 4 is a 802.1Q VLAN trunk that carries a bunch of various VLANs, and port 5 is a direct connection to the other router. Oddly, I am not sure where that speed=100Mbps setting is coming from. All of those ports are advertising everything from 10Mbps up to 1Gbps, and except for the router to router tie (which is 100Mbps because of the other router), they are all operating at 1Gbps.
Below that is all the VLANs. The first six are some specialty ham radio stuff.
Each LAN or VLAN has it’s own DHCP server and IP address pool:
add name=".101 DHCP pool" ranges=192.168.101.100-192.168.101.119
add name=".102 DHCP pool" ranges=192.168.102.100-192.168.102.119
add name=".103 DHCP pool" ranges=192.168.103.100-192.168.103.119
add name=".104 DHCP pool" ranges=192.168.104.100-192.168.104.109
add name=".106 DHCP pool" ranges=192.168.106.100-192.168.106.109
add name=".105 DHCP pool" ranges=192.168.105.100-192.168.105.109
add name=".001 DHCP pool" ranges=192.168.1.100-192.168.1.109
add address-pool=".101 DHCP pool" authoritative=after-2sec-delay disabled=no \
interface=E2-p4_101 lease-time=3h name=".101 DHCP server"
add address-pool=".102 DHCP pool" authoritative=after-2sec-delay disabled=no \
interface=VLAN_102 lease-time=3h name=".102 DHCP server"
add address-pool=".103 DHCP pool" authoritative=after-2sec-delay disabled=no \
interface=E3-p6_103 lease-time=3h name=".103 DHCP server"
add address-pool=".104 DHCP pool" authoritative=after-2sec-delay disabled=no \
interface=VLAN_104 lease-time=3h name=".104 DHCP server"
add address-pool=".106 DHCP pool" authoritative=after-2sec-delay disabled=no \
interface=VLAN_106 lease-time=3h name=".106 DHCP server"
add address-pool=".105 DHCP pool" authoritative=after-2sec-delay disabled=no \
interface=VLAN_105 lease-time=3h name=".105 DHCP server"
add address-pool=".001 DHCP pool" disabled=no interface=VLAN_001 lease-time=\
3h name=".001 DHCP server"
And each LAN or VLAN has it’s own IP address:
add address=192.168.101.251/24 interface=E2-p4_101 network=192.168.101.0
add address=192.168.102.251/24 interface=VLAN_102 network=192.168.102.0
add address=192.168.103.251/24 interface=E3-p6_103 network=192.168.103.0
add address=192.168.211.251/24 interface="E5 to Router 2" network=\
192.168.211.0
add address=192.168.104.251/24 interface=VLAN_104 network=192.168.104.0
add address=192.168.105.251/24 interface=VLAN_105 network=192.168.105.0
add address=192.168.106.251/24 interface=VLAN_106 network=192.168.106.0
add address=192.168.1.251/24 interface=VLAN_001 network=192.168.1.0
In the firewall rules, there are a couple specific allowed connections between the different LANs, but for the most part, each LAN is not allowed to communicate with the others with this rule as the LAST rule in the forward chain:
"Drop any forward packets that get this far"
There is only one masquerade rule required since everything is actually going out to the internet via the same cable connection:
add action=masquerade chain=srcnat comment="Masquerade for cable" \
out-interface=E1-p2_Cable_Internet
That should be enough to get you started…
