Hi, I want to backup my routerboard :( dunno how
Hi, I want to backup my RB750G, but can’t find a way, and doing a search here, give me this “No suitable matches were found.”
:frowning:
So please u cleaver people help me?
I just want to backup my config file, I want to download it and store it on my PC, in case something happens to my RB750G or I want to install that backup file on another RB750G and my other place, its a heavy firewall gateway config, and I tested it… its perfect
have a read of http://wiki.mikrotik.com/wiki/Manual:Configuration_Management and let us know how you go.
I just logged into my RB with a FTP client, lol, And there is only one file with the name “autosupout.old.rif”
if not… is there any other GUI method to do this, command line makes no sense to me, I want to see a browse, save, and download backup file from devices like most other devices
the command line can be very powerful and alot quicker once you get used to it. if you follow the instructions you should be right. Otherwise in winbox goto files, then click backup then grab the .backup file it just created and drag it onto your desktop
ah this looks better… :slight_smile: thx :slight_smile:
watch out though as i think that it will contain all your mac addresses and everything so that may not be the best solution to copying the config. you may want to look at that link on how to export the config and then remove with notepad all the mac addresses and such
What MAC’s will it store? the device is only a firewall, and splitting 2 LAN’s to make them private, but they use the same WAN (internet) DHCP client, no user management or anything..
That backup is quite useless feature. Why should one need a running system configuration image what can not be examined/observed/modified? By the nature of it you can not even replicate it to other similar pieces of hardware. Export has a true backup function. Unfortunately that command does get broken from time to time by MT developers.
To backup and restore the configuration i use the following
from terminal type
export file=backup15Feb2011
hit return key and wait till command line returns (note you use any name for file= )
Now in your router “Files” there will be as in my example “backup15Feb2011.rsc”, drag to your computer and to restore this configuration drag it back to files (or if the backup is still there) then reboot the router - done
Explain which version of MK has broken export commands?
For your reading pleasure:
http://forum.mikrotik.com/t/2-9-39-2-9-42-export-command-issues-on-rb112/11304/1
Note: That issue never got resolved.
Thanks, Interesting reading but and this topic is several years old it also refers to older routerboards RB112 with much less CPU power and using OS 2.9.39,41,42 , and i must admit i never had any problems with using RB411 starting with 3.30,4.11,4.15,4.16 and now RB711 also OK with 433,493,RB750, i can only assume the export issue mentioned in that topic is fixed in os versions since then and boards with higher spec CPU’s
Fine, but you as well fail to understand that configuration exporting by definition is nothing that should bring down any system, running on whatever CPU or memory configuration.
Just to test i tried a export on a 433ah which was going to 1 - 9% CPU, shot upto 100% for a few seconds during export and then back to 1 - 9% CPU, so from that quick test it says to me export puts a temp high load on the cpu, i agree with you while export is only copying the configuration and not modifying them - why the high CPU load for a *.rsc (text file) maybe it’s the priority level being assigned by routerboard to complete the export function ?
Maybe just a sloppy programming or invalid system buildup model?
Really, this isn’t a big deal. I have lots of clients who have routers running 100 percent CPU for a good portion of the day every day and they haven’t gone to the effort of upgrading. It certainly isn’t a desirable condition but 100 percent CPU for a few seconds isn’t anything to be concerned about and it isn’t poor design. What’s the option, throttle the CPU during exports and make me wait longer for the config? I’ll pass on that.
Hello, here is new open source for easy backup all your network: https://github.com/heximcz/routerboard-backup
