Hide upstream DNS name server from clients
Running
scutil --dns
on my Mac shows:
resolver #1
  nameserver[0] : 192.168.178.1
  nameserver[1] : 1.1.1.1
  if_index : 15 (en0)
  flags    : Request A records
  reach    : 0x00020002 (Reachable,Directly Reachable Address)
So my HEX is disclosing its upstream DNS name server. Is it possible to hide that from the clients and let only the HEX resolve all DNS?
Config:
[admin@MikroTik] /ip/dns> export
# 2024-04-17 10:06:46 by RouterOS 7.14.2
# software id = WX80-GBN0
# model = RB750Gr3
# serial number = HFK09EZD06Y
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.178.1 comment=defconf name=router.lan
You can explicitly specify the list of DNS servers (in this case, just 192.168.178.1) that the DHCP clients will use in the corresponding /ip dhcp-server network entry.
That’s strange. What is the configuration of the DHCP server?
Can you check that this DNS is not configured as an option in your DHCP?
> /ip/dhcp-server/network/export
add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.2.1 netmask=24
[admin@MikroTik] > /ip/dhcp-server/network/export
add address=0.0.0.0/24 comment=defconf dns-server=192.168.178.1 gateway=0.0.0.0 netmask=24
add address=192.168.178.0/24 gateway=192.168.178.1 netmask=24
[admin@MikroTik] >
You should remove the 1st entry with 0.0.0.0/24 and add dns-server=192.168.178.1 to the 2nd entry (in WinBox just enter that address in the DNS textbox).
Interesting. Let me fire up my old mac to see what scutil says.
Nope, I only see the local DNS resolver and not its upstream.
resolver #1
  nameserver[0] : 192.168.2.1
  if_index : 4 (en0)
Can you check on your Mac in the network settings, advanced settings, whether 1.1.1.1 was added manually?
This fixed it.
BTW. It was not only my Mac, but other devices got 1.1.1.1 as well, which resulted in LAN lookup failures.
