Hello MikroTik Community,
I need help troubleshooting an intermittent latency and traffic drop issue affecting multiple VLANs transported over the same Point-to-Point (PTP) wireless link between two MikroTik routers.
Network Topology
Router A
ether3: Connected to PTP wireless link
VLAN 300: Metro Internet
VLAN 301: Metro Internet 1
VLAN 302: Metro Internet 2
All three VLANs are configured on ether3.
Router B
sfp1: Connected to the same PTP network
All three VLANs are configured on sfp1.
Topology:
Router A
ether3
VLAN 300 / 301 / 302
Wireless PTP Link
(Up to 700 Mbps Capacity)
sfp1
Router B
Bridge Configuration on Router A
**Bridge 1: BR-**Metro
VLAN 301 bridged with ether2
VLAN interface has no hardware offload
ether2 shows hardware offload enabled
**Bridge 2: BR-**Metro2
VLAN 302 bridged with ether5
ether5 does not show an active hardware offload flag
Bridge settings:
use-ip-firewall: no
use-ip-firewall-for-vlan: no
use-ip-firewall-for-pppoe: no
allow-fast-path: yes
bridge-fast-path-active: yes
Problems Observed
VLAN 300, 301, and 302 experience intermittent high latency.
All three VLANs sometimes experience traffic degradation simultaneously.
Ping between router interfaces appears normal.
The wireless PTP link has a reported capacity of up to 700 Mbps.
Router A CPU utilization typically ranges from 50% to 80%, but intermittent latency also occurs when CPU utilization is below 50%.
RX drops have been observed in interface statistics.
VLAN 301 and VLAN 302 are using software bridging on Router A.
Questions
Could RX drops on the physical interface cause simultaneous intermittent latency across multiple VLANs?
Could software bridging between VLAN interfaces and Ethernet ports cause packet drops even when overall CPU utilization is below 50%?
Are there known RouterOS bridge or VLAN forwarding limitations that could explain this behavior?
Which interface counters or diagnostics should I examine to identify the exact cause?
Would using a VLAN-aware bridge with hardware offloading, if supported by the router hardware, be preferable to the current VLAN-to-Ethernet bridging configuration?
Could traffic bursts or Ethernet buffer limitations cause RX drops despite sufficient reported PTP wireless capacity?
My goal is to identify the root cause without making unnecessary changes to the production network.
Any troubleshooting recommendations would be greatly appreciated.
Thank you!
