i have client station wds
signal is -88/-84 SNR about 17
ping time is high
150msec - 900msec
no compression no nstreme
both of them atheros 5006
any idea guys?
ping time is high
150msec - 900msec
any idea guys?
post your config for client and AP.
from the console type “export file=config”
interface ethernet
set ether1 name=“ether1” mtu=1500 mac-address=00:0C:42:08:05:8C arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps comment=“” disabled=no
/ interface wireless
set TEST name=“TEST” mtu=1500 mac-address=00:0E:8E:03:AB:91 arp=enabled
disable-running-check=no radio-name=“000E8E03AB91” mode=ap-bridge
ssid=“TEST” area=“” frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2412 band=2.4ghz-b scan-list=default
rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=23 tx-power-mode=card-rates
noise-floor-threshold=default periodic-calibration=enabled
periodic-calibration-interval=60 burst-time=disabled
dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no comment=“” disabled=no
set MAX name=“MAX” mtu=1500 mac-address=00:0E:8E:03:AC:D8 arp=enabled
disable-running-check=no radio-name=“000E8E03ACD8” mode=ap-bridge
ssid=“MAX” area=“” frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2427 band=2.4ghz-b scan-list=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=radar-detect
antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=yes
/ interface wireless nstreme
set TEST enable-nstreme=no enable-polling=yes framer-policy=none
framer-limit=3200
set MAX enable-nstreme=no enable-polling=yes framer-policy=none
framer-limit=3200
/ interface wireless manual-tx-power-table
set TEST manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps
:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
set MAX manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:
/ interface wireless security-profiles
set default name=“default” mode=none authentication-types=“”
unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“” eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0=“” static-algo-1=none
static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m
/ interface wireless wds
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no
memory-limit=10 file-name=“” file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
/ interface bridge
add name=“bridge1” mtu=1500 arp=enabled protocol-mode=stp priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:67:65 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m comment=“”
disabled=no
/ interface bridge port
add interface=ether1 bridge=bridge1 priority=0x80 path-cost=10 edge=auto
point-to-point=auto external-fdb=auto comment=“” disabled=no
add interface=TEST bridge=bridge1 priority=0x80 path-cost=10 edge=auto
add interface=MAX bridge=bridge1 priority=0x80 path-cost=10 edge=auto
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460
authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2
keepalive-timeout=30 default-profile=default-encryption
/ ip accounting
simpy open the export file with notepad and copy the most important configuration here. do not post all config. only config from client and ap wireless settings
thats what i did
please anyone could tell me anything is it bug??
