Hello.
Could You please help me with this? ![]()
I’ve set up a basic config at MT 951G where I’ve configured one dhcp pool for LAN (10.1.1.0/24) and other dhcp pool for WLAN (10.10.1.0/24). The first problem was to make the WLAN pool “active”, but I found that the WiFi interface should not be in a slave mode so I’ve disabled it under the bridge.
Now the host connected via WLAN gets addresses other than “wired” hosts. The problem is that those hosts can’t reach each other between the networks (inside each the networks everything works fine). One of the solution was to set an SRCNAT, but there where no details how to do it.
Thank You
Best Regards.
