I have a mikrotik router model = RB951Ui-2HnD
I have created a hotspot and extended the wifi hotspot via a tenda router.
My issue is that, some devices connects to the hotspots once and when logged out and try to login again it says connected but no internet.
Some give the error, No internet.
What could be the issue.
Find my config file below
export compact
# 2024-01-30 13:38:52 by RouterOS 7.12.1
# software id = MZAP-W4TZ
# model = RB951Ui-2HnD
# serial number = HEW09AVYHYA
add admin-mac=78:9A:18:32:E9:4C auto-mac=no comment=defconf name=bridge
add name=hotspot
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk name="Tana Garden" supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge \
security-profile="Tana Garden" ssid="Tana Garden" wireless-protocol=802.11
/ip hotspot profile
add dns-name=tananet.com hotspot-address=192.168.88.10 login-by=cookie,http-pap name=hsprof1
add name=hs-pool-8 ranges=192.168.88.1-192.168.88.9,192.168.88.11-192.168.88.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=hs-pool-8 interface=hotspot name=dhcp1
/ip hotspot
add address-pool=hs-pool-8 addresses-per-mac=unlimited disabled=no interface=hotspot name=hotspot1 profile=hsprof1
add bridge=hotspot comment=defconf interface=wlan1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.88.1/24 interface=hotspot network=192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=\
yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1 \
out-interface-list=WAN src-address=192.168.88.1
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.88.0/24
/ip hotspot user
add name=admin
add name=TEST31
add name=HLK525
add name=GT564T
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/radius
add address=192.168.88.1 service=hotspot
/radius incoming
set accept=yes
/system clock
set time-zone-name=Africa/Nairobi
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] > [code]
[/code]
