I've created the following config for having a MikroTik router operate WLAN1 as Station Mode and WLAN2 as a Hotspot
I'd like to be able to re-route all clients to a specific IP address on ETH2 as they join the Hotspot. Would the be below config allow that?
I'm getting confused around the Hotspot address and the DHCP Pool it'd need to draw from to enable this:
oct/05/2022 15:34:13 by RouterOS 6.47.10
software id = V98M-VUTJ
model = RB952Ui-5ac2nD
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys
name=*** supplicant-identity="" wpa-pre-shared-key=*****
wpa2-pre-shared-key=*****
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country="united kingdom" disabled=no distance=indoors frequency=auto
installation=indoor security-profile=*** ssid=*** wireless-protocol=
802.11
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors
frequency=auto installation=indoor mode=ap-bridge ssid=QRCodeSEUK
wireless-protocol=802.11
add name=bridge
add interface=ether1 list=WAN
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add name=dhcp ranges=192.168.88.10-192.168.88.50
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp disabled=no interface=wlan2 lease-time=1h name=dhcp1
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.88.5/24 comment="hotspot network" interface=wlan2
network=192.168.88.0
/ip hotspot profile
add dns-name=seukqrcode.com hotspot-address=192.168.88.5 html-directory=
flash/hotspot name=hsprof1
/ip hotspot
add address-pool=dhcp disabled=no interface=wlan2 name=hotspot1 profile=
hsprof1
/ip hotspot user profile
add add-mac-cookie=no address-pool=dhcp !mac-cookie-timeout name=qrcode
/ip dhcp-client
add disabled=no interface=wlan1
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=passthrough chain=unused-hs-chain comment=
"place hotspot rules here" disabled=yes
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=masquerade chain=srcnat src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network"
/ip hotspot user
add name=admin password=12345678
add name=qrcodeusr password=qrcodeusr profile=qrcode server=hotspot1
/system clock
set time-zone-name=Europe/London
