Hotspot can not functioning
Hello peope, please I need an expertise advice on this issue urgently: I configured a hotspot with mikrotic router, The login page do display which prevent any other page to open in any browser used, but here is one of the problem, whenever I logout, I discover that I can still access the other websites which I felt should not be possible since i have logout my hotspot login details, please what Can I do to rectify this.
Secondly, I intend to connect the mikrotik ether 2 where this hotspot is configured to an already existing wireless connect through Cisco E2000, and I also discover that the hotspot login page will display but once one of hotspot username and password that I created login, the other people on this wireless network dont login again through their hotspot login detaila, and when you check the status on the other computers under this wireless network I discover that it was the first login details that always reflect on all pc which should not be so, I create different hotspot user which i expect that each user should be able to login to their to internet via their login details
Please I will appreciate any good advice and steps to rectify this urgently.
For the first, are you sure your are logged out? did you check in your mikrotik hotspot that your are looged out? if yes probably your computer’s browser need some refresh…
For the second, it looks like: nat - masquede problem. if you are doing it, disable it.
Thanks, I just discover that the cookies need to be disable,and i did just that and every problem was resolved. Thanks again
