Hello, I’m new to networking. So I’ve been given a task to set up a MikroTik hotspot network where the user authentication is handled by a remote MikroTik router (RB1100AHx4) using User Manager.
Here’s the setup:
[Client Devices]
RB750Gr3 (Hotspot + WireGuard Client) → ISP
RB1100x4 (WireGuard Server + User Manager) ->ISP
My problem is clients connecting to the hotspot on the RB750Gr3 experience very slow internet speeds (around 1–2 Mbps), but it only happened when using username and password from user manager. Both router using ROS 7.6. Here is my configuration:
# aug/01/2025 08:33:11 by RouterOS 7.6
# software id = **ELIDED**
# model = RB1100x4
# serial number = **ELIDED**
add name=bridge1
set [ find default-name=ether1 ] name=ether1-ISP
set [ find default-name=ether2 ] name=ether2-AP
/interface wireguard
add listen-port=51820 mtu=1380 name=wireguard1
/ip hotspot profile
set [ find default=yes ] login-by=cookie,http-chap,https,http-pap use-radius=\
yes
add dns-name=kumala-group-hotspot.com hotspot-address=10.10.10.1 login-by=\
cookie,http-chap,https,http-pap name=hsprof1 use-radius=yes
add name=dhcp_pool0 ranges=10.10.10.2-10.10.10.254
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254
add name=dhcp_pool2 ranges=103.94.9.169-103.94.9.172,103.94.9.174
add address-pool=dhcp_pool2 interface=ether1-ISP name=dhcp1
/ip hotspot
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=hotspot1 \
profile=hsprof1
/port
set 0 name=serial0
set 1 name=serial1
/user-manager profile
add name=admins name-for-users=admins starts-when=first-auth
add name=users name-for-users=users starts-when=first-auth
/user-manager user
add name=kumala-user
add name=kumala-user2
add name=kumala-admin
add name=fadiyah shared-users=10
add name=ardi shared-users=10
add name=nanes shared-users=10
add bridge=bridge1 interface=ether2-AP
add bridge=bridge1 interface=ether6
/interface l2tp-server server
set enabled=yes
/interface wireguard peers
add allowed-address=192.168.10.2/32 interface=wireguard1 public-key=\
[spoiler]"B/JdMlsamYxmDzxQdAiHk4w+Cud6r2mP88TAa+4bTXM="[/spoiler]
add address=10.10.10.1/24 interface=bridge1 network=10.10.10.0
add address=192.168.10.1/24 interface=wireguard1 network=192.168.10.0
add address=103.94.9.173/29 interface=ether1-ISP network=103.94.9.168
add address=10.10.10.0/24 gateway=10.10.10.1
add address=103.94.9.168/29 gateway=103.94.9.173
set servers=103.94.11.127,103.94.10.147
add action=accept chain=input comment="Allow RADIUS from WG client" port=\
1812,1813 protocol=udp src-address=192.168.10.2
add action=accept chain=input disabled=yes dst-port=1813 protocol=udp \
src-address=127.0.0.1
add action=accept chain=input disabled=yes dst-port=1812 protocol=udp \
add action=accept chain=input disabled=yes src-address=127.0.0.1 \
src-address-list=127.0.0.1
add action=accept chain=input disabled=yes dst-address=127.0.0.1
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=accept chain=input disabled=yes port=1812 protocol=udp \
src-address=10.10.20.1
add action=accept chain=input comment="Allow WireGuard VPN" dst-port=13231 \
protocol=udp
add action=masquerade chain=srcnat out-interface=ether1-ISP
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=yes out-interface=ether1-ISP src-address=10.10.10.0/24
/ip hotspot user
add disabled=no dst-address=0.0.0.0/0 gateway=103.94.9.170 routing-table=main \
suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set winbox port=8877
set api-ssl disabled=yes
/radius
add address=127.0.0.1 service=login,hotspot src-address=127.0.0.1
/radius incoming
set accept=yes
/system clock
set time-zone-name=Asia/Jakarta
/system identity
set name=kumala-server
/system logging
add topics=radius
add topics=radius,debug
add topics=manager
add topics=interface
add topics=route
/user-manager
set certificate=*0 enabled=yes use-profiles=yes
/user-manager router
add address=192.168.10.2 name=RB750
add address=127.0.0.1 name=server
/user-manager user-profile
add profile=users user=kumala-user
add profile=admins user=kumala-admin
add profile=admins user=fadiyah
add profile=users user=kumala-user2
add profile=admins user=ardi
add profile=users user=nanes
# aug/01/2025 09:31:36 by RouterOS 7.6
# model = RB750Gr3
add name=bridge1
set [ find default-name=ether2 ] disabled=yes name=ether2-Zerotier_VPN
set [ find default-name=ether3 ] name=ether3-AP
/ip hotspot profile
set [ find default=yes ] dns-name=kumala-hotspot.com use-radius=yes
add dns-name=kumala-hotspot.com hotspot-address=10.10.20.1 html-directory=\
flash/hotspot name=hsprof1 use-radius=yes
add name=dhcp_pool0 ranges=\
192.168.30.1-192.168.30.9,192.168.30.11-192.168.30.254
add name=dhcp_pool1 ranges=10.10.20.2-10.10.20.254
add name=dhcp_pool2 ranges=\
192.140.20.1-192.140.20.27,192.140.20.29-192.140.20.254
add address-pool=dhcp_pool1 interface=bridge1 name=dhcp2
/ip hotspot
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=hotspot1 \
profile=hsprof1
/port
set 0 name=serial0
/queue type
add kind=pcq name=UPLOAD pcq-classifier=src-address pcq-rate=512k
add kind=pcq name=DOWNLOAD pcq-classifier=dst-address pcq-rate=1M
/routing table
add disabled=yes fib name=via-softeth
add bridge=bridge1 interface=ether3-AP
add allowed-address=0.0.0.0/0 endpoint-address=103.94.9.173 endpoint-port=\
51820 interface=wireguard1 persistent-keepalive=5h47m44s public-key=\
[spoiler]"iGGwdtEPDkkKcKIhZz1sDRCJlNGivIWcSj8VlRqdNE8="[/spoiler]
add address=10.10.20.1/24 interface=bridge1 network=10.10.20.0
add address=192.168.10.2/24 comment="wireguard ip's" interface=wireguard1 \
/ip dhcp-client
add interface=ether1-ISP
add address=10.10.20.0/24 dns-server=8.8.8.8 gateway=10.10.20.1
add address=192.140.20.0/24 gateway=192.140.20.28
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
add action=accept chain=forward disabled=yes hotspot=auth
"Allow established/related connections" connection-state=\
established,related disabled=yes
add action=accept chain=pre-hotspot disabled=yes hotspot=auth
out-interface=ether1-ISP src-address=10.10.20.0/24
add action=accept chain=srcnat comment="Bypass NAT for RADIUS via WG" \
dst-address=192.168.10.1 dst-port=1812,1813 protocol=udp src-address=\
192.168.10.2
/ip hotspot user
add disabled=yes name=kumala-admin
add name=admin
/ip proxy
set enabled=yes
/ip service
/radius
add address=192.168.10.1 service=login,hotspot,wireless
/radius incoming
set accept=yes
/system clock
set time-zone-name=Asia/Makassar
/system identity
set name=kumala-hotspot
/system logging
add topics=hotspot
add topics=manager
add topics=firewall
add topics=radius
