Hotspot filtering.
Hello, how can I make some custom filters rules by user on the hotspot? where to put the jump?
Regards,
Fran
You can define the chain to jump to for hotspot user filtering in the hotspot user profil (“incoming filter”/“outgoing filter”).
Best regards,
Christian Meis
Thanks Chris, but I tried that and didn't work for some reason, this is my config.
Hotspot:
/ ip hotspot
add name="OSM-HOTSPOT" interface=bridge1 address-pool=OMC-POOL profile=hsprof1 idle-timeout=none keepalive-timeout=none disabled=no
/ ip hotspot service-port
set ftp ports=21 disabled=no
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
add name="hsprof1" hotspot-address=192.168.111.1 dns-name="test" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
/ ip hotspot user
add server=OSM-HOTSPOT name="fran" password="123456" profile=fran comment="" disabled=no
add server=OSM-HOTSPOT name="ricardo" password="123456" profile=default comment="" disabled=no
/ ip hotspot user profile
set default name="default" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1 transparent-proxy=yes open-status-page=always advertise=no
add name="fran" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1 outgoing-filter="blocksite" transparent-proxy=yes open-status-page=always advertise=no
add name="ricardo" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1 transparent-proxy=yes open-status-page=always advertise=no
/ ip hotspot walled-garden
add server=OSM-HOTSPOT method="" action=deny comment="" disabled=no
as you can see i have two profiles with two users, i am trying to block on one user a single site with the filter "blocksite"
Firewall:
0 D chain=forward hotspot=from-client,!auth action=jump jump-target=hs-unauth
1 D chain=forward hotspot=to-client,!auth action=jump jump-target=hs-unauth-to
2 D chain=hs-input action=jump jump-target=pre-hs-input
3 D chain=hs-input protocol=udp dst-port=64872 action=accept
4 D chain=hs-input protocol=tcp dst-port=64872-64875 action=accept
5 D chain=hs-input hotspot=!auth action=jump jump-target=hs-unauth
6 D chain=hs-unauth protocol=tcp action=reject reject-with=tcp-reset
7 D chain=hs-unauth action=reject reject-with=icmp-net-prohibited
8 D chain=hs-unauth-to action=reject reject-with=icmp-host-prohibited
9 ;;; Custom block site
chain=forward action=jump jump-target=blocksite
10 chain=blocksite dst-address=200.200.200.1 hotspot=from-client,!auth action=drop
