I have seen some post regarding this issue in hotspot, the “from” ip address is DIFFERENT from “to” ip address and I have never seen a solution for this yet in the forum.
Flags: S - static, H - DHCP, D - dynamic, A - authorized, P - bypassed
MAC-ADDRESS ADDRESS TO-ADDRESS SERVER IDLE-TIMEOUT
3 A C4:85:08:69:86:47 192.168.11.37 192.168.11.34 AFGS-HS-S…
4 A 00:26:82:72:E8:E3 192.168.11.40 192.168.11.41 AFGS-HS-S…
7 A 00:26:82:75:49:2A 192.168.11.30 192.168.11.45 AFGS-HS-S…
8 A B8:F9:34:7B:6B:A4 192.168.11.49 192.168.11.50 AFGS-HS-S…
9 A 60:D8:19:94:09:08 192.168.11.32 192.168.11.33 AFGS-HS-S…
11 A 14:89:FD:28:34:5A 192.168.11.38 192.168.11.39 AFGS-HS-S…
If you mean the entries in “/ip hotspot host”, that is the universal hotspot NAT. It allows clients to use the hotspot if they have a static ip outside the hotspot localnet ip range.
Before, my MT can manage to issue the same IP from my DHCP to hotspot, which is very useful in tracking users ip address from hotspot without checking my dhcp servers leases.
I need my hotspot to get the same ip address from my dhcp, which is working before on my previous hotspot setup, now I dont know what is wrong.
Anyway, I had 3 interfaces set to Bridge for this hotspot.
Hi, you need to change the hotspot user profile to none not only in servers sheet. It works fine im tested it on more hotspots, in hosts now only one IP.
Where do you see an entry for this in “/ip hotspot user profile”? I don’t know what this is supposed to mean.
edit: I see where you can assign an address pool there now, but it appears to be set to none by default. You can also set the pool with a radius Framed-Pool attribute, but that is also not sent by default.
You can also assign a specific ip to a user in “/ip hotspot user” with the address attribute and the radius Framed-IP-Address attribute. Check if you are doing that also, but both are disabled or not sent by default.
same problem, one client use 2 IP address in the pool!
/ip/hotspot/host>pr
Flags: A, P - BYPASSED
Columns: MAC-ADDRESS, ADDRESS, TO-ADDRESS, SERVER
0 A F2:XX:XX:51:0A:FE 10.1.99.248 10.1.99.249 hotspot1
/ip/hotspot> print detail
Flags: X - disabled, I - invalid, S - HTTPS
0 name=“hotspot1” interface=bridge-HS profile=hsprof1 idle-timeout=5m
keepalive-timeout=none login-timeout=none addresses-per-mac=1
ip-of-dns-name=10.1.99.1 proxy-status="running
/ip/pool/used> pr
Columns: POOL, ADDRESS, OWNER, INFO
POOL ADDRESS OWNER INFO
HS-lapachos 10.1.99.248 DHCP F2:XX:XX:51:0A:FE
HS-lapachos 10.1.99.249 hotspot F2:XX:XX:51:0A:FE
Some Help?
Please some can Help, i need get HotsSpot Use one address
