i have just setup hotspot on a MT box…but i cannot login after the login page appeared:
below is the exported info from the gateway:
/ ip hotspot
add name=“hs-hotspot1” interface=hotspot1 address-pool=hs-pool-3
profile=hsprof1 idle-timeout=5m keepalive-timeout=none addresses-per-mac=2
disabled=no
/ ip hotspot service-port
set ftp ports=21 disabled=no
/ ip hotspot profile
set default name=“default” hotspot-address=0.0.0.0 dns-name=“”
html-directory=hotspot rate-limit=“” http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
add name=“hsprof1” hotspot-address=192.168.26.254 dns-name=“codespot.com”
smtp-server=0.0.0.0 login-by=http-chap split-user-domain=no use-radius=no
/ ip hotspot user
add server=hs-hotspot1 name=“admin” password=“rubbish” profile=default
comment=“” disabled=no
/ ip hotspot user profile
set default name=“default” address-pool=hs-pool-3 idle-timeout=none
keepalive-timeout=2m status-autorefresh=1m shared-users=1
transparent-proxy=yes open-status-page=always advertise=no
