Hotspot Issue
Hello House
I have an issue with my hotspot, within neighborhood, the signal strength is about 4 to 5bars, immediately after the neighborhood, the hotspot can not connect to server with two to three bars, what can the problem be? how do i go about solving the problem? How can i have a good coverage? how can i boost my signal?
Remember that it isn’t just the signal from the router to the laptops… but also the laptops BACK TO the router. Most laptops have tiny little antennas and can’t send a signal very far. So, even if you can blast a signal 10 miles… your little laptop can only send a signal back a few hundred feet at most.
Solution = More Access Points throughout the area to be covered. NOT just a single Access Point. You need 1 every few hundred feet in every direction… depending on terrain, buildings, etc.
