hotspot login page help
I have the hotspot setup. I edited the login.html to say what I want it to.
I want to check it in a browser, I open firefox and type in the dns in the address bar and it takes me to a log in page that says enter your password.
How can I see the page I created?
Have you tried connecting to the hotspot and using it as the end user would?
Its just showing a blank page not allowing any traffic.
I would say you messed up your HTML. Reset your HTML and then see if it works.
what did you use to edit the login page html? Nearly all wysiwyg editors will break the code. To edit the Text use notepad++ or similar. For advanced editing you will need a bit of html coding knowledge or take advantage of some of the template posted in the forum
