hotspot question
Is possible to use hotspot only for specified IPs without setting up the ip-binding?
Thank you in advance
HotSpot is used per entire interface.
Either those addresses are not connected to this interface, or additional settings should be used to exclude addresses from HotSpot authentication [ip-binding].
thanks for reply
