I have semi-successfully configured the hotspot for a rb150 on ROS v4.11.
Where I seem to be having trouble is with the redirect portion of the hotspot.
The hostname isn't resolving, resulting in a "server not found" message in the browser.
I'm testing from windows and have tried flushing the DNS cache and re-leasing the hotspot IP. Typically the name of the hotspot is not pingable from windows, but is from a terminal in winbox. When I plug the IP address in to the redirected URL (http://192.168.26.1/login?dst=http%3A%2F%2Fwww.google.com%2F), I am able to get the login page.
Any help would be greatly appreciated.
(if I am able to get past this, I have a few other questions about hotspots and bridge plus how to get initial https:// URLs to redirect to the login page)
[admin@MikroTik] > ping hotspot
192.168.26.1 64 byte ping: ttl=64 time=8 ms
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 8/8.0/8 ms
[admin@MikroTik] > export
jan/02/1970 16:58:42 by RouterOS 4.11
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1518 mac-address=00:0C:42:12:3D:13
master-port=none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1518 mac-address=00:0C:42:12:3D:14
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1518 mac-address=00:0C:42:12:3D:15
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1518 mac-address=00:0C:42:12:3D:16
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1518 mac-address=00:0C:42:12:3D:17
master-port=none mtu=1500 name=ether5 speed=100Mbps
set default authentication-types="" eap-methods=passthrough group-ciphers=""
group-key-update=5m interim-update=0s management-protection=disabled
management-protection-key="" mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key=""
wpa2-pre-shared-key=""
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
add dns-name=hotspot hotspot-address=192.168.26.1 html-directory=hotspot
name=hsprof1 rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
add name=hs-pool-5 ranges=192.168.26.50-192.168.26.100
add address-pool=hs-pool-5 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=ether5 lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hs-pool-5 addresses-per-mac=2 disabled=no idle-timeout=5m
interface=ether5 keepalive-timeout=none name=hotspot1 profile=hsprof1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default
use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption
only-one=default use-compression=default use-encryption=yes
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=
backbone type=default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location=""
time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-only boot-protocol=bootp
cpu-frequency=175MHz cpu-mode=regular enable-jumper-reset=yes
enter-setup-on=any-key force-backup-booter=no silent-boot=yes
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass
word,web,sniff,sensitive,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb
ox,password,web,sniff,sensitive,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy
,test,winbox,password,web,sniff,sensitive"
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:BF:48:6A:70:1A
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.13.254/24 broadcast=192.168.13.255 comment="" disabled=no
interface=ether1 network=192.168.13.0
add address=192.168.26.1/24 broadcast=192.168.26.255 comment=
"hotspot network" disabled=no interface=ether5 network=192.168.26.0
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.26.0/24 comment="hotspot network" gateway=192.168.26.1
add address=192.168.88.0/24 comment="" gateway=192.168.88.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 servers=192.168.13.1
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=
"place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=no src-address=192.168.26.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
add comment="" disabled=no name=admin password=secret profile=default
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
192.168.13.1 scope=30 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=
yes interface=all memory-limit=10 memory-scroll=no only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
[admin@MikroTik] >
