[HotSpot] - restrict access to web pages for certain users
Is is possible to restrict access to certain webpages (like facebook.com, torrent sites…) for a hotspot user.
Example:
User with login “userA” → Can access everything
User with login “userB” → Can access everything except Facebook.com, twitter.com
Use walled garden >> http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot/Walled_Garden
Ok, I thought that Walled Garden is only for allowing some sites to passthrough the hotspot.–
You will need to play around with the proxy to get it working. Basically have two methods of doing this.
1.) You have two different user profiles in the RB. One of them has “use transparent proxy” enabled and the other doesn’t. UserB’s access code is tied to the profile that tells it to use the transparent proxy. Set up the appropriate access rules in the proxy.
2.) You have two different user profiles in the RB. You use RADIUS, and upon a signing into the network, RADIUS tells the RB to add userB to the address list. You then use a NAT rule to redirect userB’s HTTP traffic to the proxy.
The main thing to keep in mind is that the transparent proxy ONLY works with HTTP traffic. So if they go to the secured version of Facebook etc. it will not block them. You would need a more comprehensive solution than what MikroTik offers out of the box.
