I have a scenario at a university where 4 profiles for various users on the lan are needed. I have students, staff, admin and server room.
using hotspot, is there anyway that you can specify, if you log in via a certain profile (eg students), that they will get an ip in a certain range? i want this so that i can add limitations to those ranges via IP firewall. or are there any other suggestions?
http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot/User#User_Profile
Read about ‘address-list’ property.
Create four hotspot user profiles and set it’s ‘address-list’ property according to your needs (students, staff, admin and server room).
With these settings you’ll be able to make limitation based on firewall’s address lists, not assigned IP addresses.
Thanks for the response. I did research and was sure it was something to do with that. However i haven’t played with address lists too much. I have been tinkering and haven’t been able to succeed; below is my config
[admin@MikroTik] /tool user-manager profile limitation> print detail
0 name="Customers" owner=admin download-limit=0B upload-limit=0B transfer-limit=0B uptime-limit=0s rate-limit-rx=716800B rate-limit-tx=716800B rate-limit-min-rx=716800B
rate-limit-min-tx=716800B group-name="Customers" ip-pool="" address-list="Customers"
[admin@MikroTik] > ip hot user profile pri
Flags: * - default
0 * name="default" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1
transparent-proxy=no
1 name="Customers" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1
address-list="Customers" transparent-proxy=yes open-status-page=always advertise=no
/ip firewall address-list> pri
Flags: X - disabled, D - dynamic
# LIST ADDRESS
0 Customers 0.0.0.0
/ip firewall filter> print
0 chain=forward action=drop src-address-list=Customers connection-mark=facebook
[admin@MikroTik] /ip firewall mangle> pri
0 chain=prerouting action=mark-connection new-connection-mark=facebook passthrough=no dst-address=173.252.96.0/19
1 chain=prerouting action=mark-connection new-connection-mark=facebook passthrough=no dst-address=66.220.144.0/20
2 chain=prerouting action=mark-connection new-connection-mark=facebook passthrough=no dst-address=69.171.224.0/19
On RADIUS server define user groups (students, staff, admin and server room) with different ‘Mikrotik-Mark-Id’.
This gives you ability to mark traffic from/to user belonging to specific group or add user IP address to firewall address list.
I managed to get the initial idea with radius working. it seems to be something to do with using the same name (eg students) on all the profiles relevant settings/names. (address lists, user profiles and user manager limitations)
however i am still interested on learning about the radius/client. especially since i cant find the sub menu . or is it a separate package?
RouterOS has RADIUS client built-in, you can access it via Winbox menu.
Wiki article mentioned in my previous post has all necessary information about RouterOS RADIUS client configuration and attributes.
As I wrote earlier, create RADIUS user groups with with different ‘Mikrotik-Mark-Id’ attributes and add hotspot users to specific groups.
Create firewall mangle rules with chain names same as ‘Mikrotik-Mark-Id’ attributes and use them to mark traffic or add hotspot users to firewall address lists.
