Hi, I have a problem with the hotspot walled garden and ip walled garden, I need to be reachable with winbox and messenger without authentication of the hotspot.
Look around the forum and not get information on what port, ip and domains I release through the walled garden, so that users can take any messenger and winbox ip of the lan without authentication (hotspot interface).
i have access to internal resources (printer, mail server, ftp) with walled garden and walled garden ip
Probe ports 443 1863 8291 but dont work msn and winbox is not an option enable the transparent proxy in mikrotik hotspot
I am already running Load Balancing over Multiple Gateways with transparent proxy(linux squid) and parent control(linux dansguardian)
clients (10.1.1.0/24) <-------> (10.1.1.11)MK V3(192.168.14.1)wan1<------>(192.168.14.15)proxy and parent control
(192.168.15.1)wan2<------>(192.168.15.15)proxy and parent control
Someone can help and 1 month ago that I tested and I could not make it work. i have version 3 mikrotik
Ok, veo que hablas español creo que será más facil decirte eso en nuestro idioma nativo aunque no es lo correcto ya que es un forum internacional y se debe escribir en ingles todo asi que lo escribire en ambos idiomas.
¿Tu hotspot es privado o es para acceso publico?
¿Sabes que equipos se conectaran a tu hotspot?
Suponiendo que conozcas que equipos se van a conectar puedes intentar darle permisos con la MAC de los equipos y los agregas en el IP Binding…
Are the hotspot is public o private?
Do you know what pc or notebook connect to the hotspot?
Well if you know the MAC of your pc’s you can add the MAC into the IP Binding…
