Hotspot walled garden and per user limit
I have defined walled garden ip list for certain hotspot server, and i have defined per user limit rate for this hotspot. Will this rate limit apply to users that are in garden ip list?
Basically how can i achieve that users bypass captive portal, but are still limited bandwidth wise.
Thank you
Walled Garden is to bypass the hostspot authentication mostly by destination (e.g. google.com).
To bypass auth for a specific device, effectively bypassing the hotspot, for both MAC and IP, you should add that user MAC/IP to IP Bindings.
As with any of the above methods this device is no longer a hotspot authenticated user, a dynamic user-based simple queue won’t be created; you can solve that by creating it yourself, using its IP as target and setting the limits there.
Keep in mind simple queues are sequential, if you set a hotspot server limitation (not a user one) this queue should be before it.
