Hotspot + Web-proxy
Hi!
I’d like to ask your help!
I want to set a hot-spot with a web-proxy so I would be able to block some pages.
I used these manuals to set up the system:
http://wiki.mikrotik.com/wiki/How_to_Block_Websites_%26_Stop_Downloading_Using_Proxy
http://wiki.mikrotik.com/wiki/Hotspot
But it seems they do not work together. Hotspot works, but the page blocking don’t.
Also tried to block some pages using only the hotspot trough Walled Garden, but didn’t work.
Figured out that the problem is sowhere in the firewall settings, but I don’t know where exactly.
So I’d like to ask one of you to post a working settings so I can reconfigure my firewall to work hotspot and web-proxy together.
Thank you for the help!
Regards
punn
Transparent proxy should be enabled for /ip hotspot user profile.
Add web-pages you want to block to /ip proxy access it should work.
What do you have at /ip proxy access?
