Is it possible to create hotspot with only pin for authentication??
You can use normal user/password and use the same “word” for both.
In html or javascript you would post the same value.
I’ll try to include an example later if needed.
$(if chap-id)
<form name="sendin" action="$(link-login-only)" method="post">
<input type="hidden" name="username" />
<input type="hidden" name="password" />
<input type="hidden" name="dst" value="$(link-orig)" />
<input type="hidden" name="popup" value="true" />
</form>
<script type="text/javascript" src="/md5.js"></script>
<script type="text/javascript">
function doLogin() {
document.sendin.username.value = document.login.username.value;
document.sendin.password.value = hexMD5('$(chap-id)' + document.login.username.value + '$(chap-challenge)');
document.sendin.submit();
return false;
</script>
$(endif)
is it possable to do something like Aerohive private preshare key on mikrotik?
Something like this: https://www.youtube.com/watch?v=b6SkofK2pCI&ebc=ANyPxKo1cpp1kaxFAT5vCwNwD1g1kdFKB9FJOdbu3xN5ouLAfpdcm4_jXBIvR7KY4u3hbSyQaBFtPVazqn3HxnGDXX5mjwtZqA
The only thing I can think of is a virtual AP.
I haven’t tried this so can’t be much more of assistance.
http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#VirtualAP
yes but with virtual ap i don get user menagment.
i notice that in userman I can enter preshare key i is mean that I can define preshare key by usert
If I understand what you are referring to, the client router must
communicate with usermanager over a secured link.
That is not the user link to associate with the AP.
Edit: Creating the virtual AP looks like the best way to go if you
need user groups that are separate and secure.
