I´ve configurated RB100 like HotSpot,
DHCP works correctly in Pc´s in Lan, but when I opn browser,don´t appears login page.
Paste your configuration
/ interface ethernet
set ether1 name=“ether1” mtu=1500 mac-address=00:0C:42:13:53:C0 arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps comment=“” disabled=no
set ether2 name=“ether2” mtu=1500 mac-address=00:0C:42:13:53:C1 arp=enabled
set ether3 name=“ether3” mtu=1500 mac-address=00:0C:42:13:53:C2 arp=enabled
set ether4 name=“ether4” mtu=1500 mac-address=00:0C:42:13:53:C3 arp=enabled
set ether5 name=“ether5” mtu=1500 mac-address=00:0C:42:13:53:C4 arp=enabled
/ interface wireless security-profiles
set default name=“default” mode=none authentication-types=“” unicast-ciphers=“”
group-ciphers=“” wpa-pre-shared-key=“” wpa2-pre-shared-key=“”
eap-methods=passthrough tls-mode=no-certificates tls-certificate=none
static-algo-0=none static-key-0=“” static-algo-1=none static-key-1=“”
static-algo-2=none static-key-2=“” static-algo-3=none static-key-3=“”
static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no
memory-limit=10 file-name=“” file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=pap,chap,mschap1,mschap2
default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2
keepalive-timeout=30 default-profile=default-encryption
/ ip pool
add name=“hs-pool-2” ranges=10.5.50.2-10.5.50.254
/ ip ipsec proposal
add name=“default” auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
lifebytes=0 pfs-group=modp1024 disabled=no
/ ip dhcp-server
add name=“dhcp1” interface=ether2 lease-time=1h address-pool=hs-pool-2
bootp-support=static authoritative=after-2sec-delay disabled=no
/ ip dhcp-server config
set store-leases-disk=5m
/ ip dhcp-server lease
/ ip dhcp-server network
add address=10.5.50.0/24 gateway=10.5.50.1 comment=“hotspot network”
/ ip hotspot
add name=“hotspot1” interface=ether2 address-pool=hs-pool-2 profile=hsprof1
idle-timeout=5m keepalive-timeout=none addresses-per-mac=2 disabled=no
/ ip hotspot service-port
set ftp ports=21 disabled=no
/ ip hotspot profile
set default name=“default” hotspot-address=0.0.0.0 dns-name=“”
html-directory=hotspot rate-limit=“” http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
add name=“hsprof1” hotspot-address=10.5.50.1 dns-name=“dns.sonimar”
/ ip hotspot user
add name=“admin” password=“admin” profile=default comment=“” disabled=no
/ ip hotspot user profile
set default name=“default” idle-timeout=none keepalive-timeout=2m
status-autorefresh=1m shared-users=unlimited transparent-proxy=yes
open-status-page=always advertise=no
/ ip proxy
set enabled=no src-address=0.0.0.0 port=8080 parent-proxy=0.0.0.0:0
cache-administrator=“webmaster” max-disk-cache-size=none
max-ram-cache-size=8000KiB cache-only-on-disk=no
maximal-client-connections=1000 maximal-server-connections=1000
max-object-size=4000KiB max-fresh-time=3d
/ ip accounting
set enabled=yes account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=yes address=192.168.1.2/32
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=62.14.2.1 secondary-dns=62.14.63.145 allow-remote-requests=no
cache-size=2048KiB cache-max-ttl=1w
/ ip dns static
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m
inactive-flow-timeout=15s
/ ip address
add address=10.5.50.1/24 network=10.5.50.0 broadcast=10.5.50.255
interface=ether2 comment=“” disabled=no
add address=192.168.1.249/24 network=192.168.1.0 broadcast=192.168.1.255
interface=ether3 comment=“” disabled=no
/ ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
/ ip route
add dst-address=0.0.0.0/0 gateway=10.5.50.1 scope=255 target-scope=10 comment=“”
disabled=no
/ ip firewall nat
add chain=srcnat src-address=192.168.92.0/24 action=masquerade
comment=“masquerade hotspot network” disabled=no
add chain=srcnat src-address=10.5.50.0/24 action=masquerade comment=“masquerade
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m tcp-syncookie=no
/ ip firewall filter
/ ip firewall service-port
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
/ system ntp server
set enabled=no broadcast=no multicast=no manycast=yes
/ system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/ system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
enter-setup-on=any-key cpu-mode=power-save memory-test=no
cpu-frequency=175MHz boot-protocol=bootp enable-jumper-reset=yes
/ system logging
add topics=info prefix=“” action=memory disabled=no
add topics=error prefix=“” action=memory disabled=no
add topics=warning prefix=“” action=memory disabled=no
add topics=critical prefix=“” action=echo disabled=no
/ system logging action
set memory name=“memory” target=memory memory-lines=100 memory-stop-on-full=no
set disk name=“disk” target=disk disk-lines=100 disk-stop-on-full=no
set echo name=“echo” target=echo remember=yes
set remote name=“remote” target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 check-interval=1d
user=“”
/ system clock manual
set time-zone=+00:00 dst-delta=+00:00 dst-start=“jan/01/1970 00:00:00”
dst-end=“jan/01/1970 00:00:00”
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes no-ping-delay=5m
automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term=“” disabled=no
/ system identity
set name=“MikroTik”
/ system note
set show-at-login=yes note=“”
/ port
set serial0 name=“serial0” baud-rate=115200 data-bits=8 parity=none stop-bits=1
flow-control=none
/ ppp profile
set default name=“default” use-compression=default use-vj-compression=default
use-encryption=default only-one=default change-tcp-mss=yes comment=“”
set default-encryption name=“default-encryption” use-compression=default
use-vj-compression=default use-encryption=yes only-one=default
/ ppp aaa
set use-radius=no accounting=yes interim-update=0s
/ queue type
set default name=“default” kind=pfifo pfifo-limit=50
set ethernet-default name=“ethernet-default” kind=pfifo pfifo-limit=50
set wireless-default name=“wireless-default” kind=sfq sfq-perturb=5
sfq-allot=1514
set synchronous-default name=“synchronous-default” kind=red red-limit=60
red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name=“hotspot-default” kind=sfq sfq-perturb=5 sfq-allot=1514
add name=“default-small” kind=pfifo pfifo-limit=10
/ queue simple
/ user
add name=“admin” group=full address=0.0.0.0/0 comment=“system default user”
disabled=no
/ user group
add name=“read” policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!ftp
,!write,!policy
add name=“write” policy=local,telnet,ssh,reboot,read,write,test,winbox,password,w
eb,!ftp,!policy
add name=“full” policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,
password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ tool bandwidth-server
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
/ tool mac-server ping
set enabled=yes
/ tool e-mail
set server=0.0.0.0 from=“<>”
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name=“” file-limit=10
streaming-enabled=no streaming-server=0.0.0.0 filter-stream=yes
filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ routing ospf
set router-id=0.0.0.0 distribute-default=never redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-bgp=no
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate
authentication=none prefix-list-import=“” prefix-list-export=“” disabled=no
/ routing bgp
set enabled=no as=1 router-id=0.0.0.0 redistribute-static=no
redistribute-connected=no redistribute-rip=no redistribute-ospf=no
/ routing rip
set redistribute-static=no redistribute-connected=no redistribute-ospf=no
redistribute-bgp=no metric-static=1 metric-connected=1 metric-ospf=1
metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
/ radius incoming
set accept=yes port=1700
/ snmp
set enabled=no contact=“” location=“”
/ snmp community
set public name=“public” address=0.0.0.0/0 read-access=yes
[admin@MikroTik] >
Make sure that you have NOT assigned any proxy address in Browser.
Your configuration seems to be ok…Too
much man
for the hotspot to work, DNS must be functional on the device. I see you have public IPs entered for DNS servers, but your default route seems to point to 10.5.50.1, which seems just wrong, and you have no public IP address configured on your board to originate these DNS requests, and for them to be replied to on.
Ok, It´s working now. Thanks.
