How 5ghz-a/n/ac works ??
I set wlan2 on my wap-ac to 5ghz-a/n/ac
A non-AC capable client cannot see its SSID.
On MT wlan status window, it is running channel 5180/20/ac
All ok if Band is set to 5ghz-A/N
How should I configure wlan in a wireless environment where older devices are present ???
Play with extension channel.
What are your clients?
I’m wondering if it is more a problem with the channel chosen vs the A/N/AC problem.
Yes , it was an unsupported channel choice… not an A/N/AC problem…
