Hi all,
I have a json file with IP address and other data. I try to parse it with JParseFunctions (https://github.com/Winand/mikrotik-json-parser). The script running well on terminal, but I don’t know how to make it works on /System/Scripts.
JSON code
"ip": "108.177.16.30",
"hostname": "30.r1.unverified-forwarding.1e100.net",
"city": "Brussels",
"region": "Brussels Capital",
"country": "BE",
"loc": "50.8505,4.3488",
"org": "AS15169 Google LLC",
"postal": "1000",
"timezone": "Europe/Brussels"
My script
:global JSONLoad;
:global parsedIP "X";
:set parsedIP {
return (:put ([$JSONLoad "ipaddress-api.json"]->"ip"))
:log warning $parsedIP;
Thanks in advance
I have run the script and make JSONLoad as global variable.
Too much frills and mess…
:global JSONLoad
:log warning ([$JSONLoad "ipaddress-api.json"]->"ip")
Thanks @rextended, its works.
I’ll try it with more complex script to get dynamic public IP of my ISP and stored it on address list.
" get dynamic public IP of my ISP and stored it on address list"
All this for simply that? Ignoring the existence of MikroTik’s Cloud DDNS:
/ip firewall address-list
remove [find where list="current-wan-ip"]
add list="current-wan-ip" address=[:resolve "myip.opendns.com" server=208.67.222.222]
Is better you expose what you want at the end, that ask for solve something inside.
If I misunderstood your description, explain yourself better, even with an example.
Thanks again. This is what I need.
I’am currently using ipinfo.io (json format) to get dynamic public ip.
Public IP is also available as text by this link https://ipinfo.io/ip
