how can I see RB behind RB?
this is the configuration I want to do:
now in my computer the setting are
IP:10.0.0.50/24
DG:10.0.0.254
when I run winbox I want to be able to see all the RB in my network, and bot just the 10.0.0.254
how can I do this ?
(in 10.0.0.254 - there is only one firewall rule nat - masquerade )
Thanks ,
Use dst nat or romon.
can you explain please?
what I need to do and wherer ?
Thanks ,
https://wiki.mikrotik.com/wiki/Manual:RoMON
and if I have some older version of RB?
can’t I do something in the firewall level?
Thanks ,
Dst nat.
Or update the ros to newer.
how can I dst nat?
I have try bit I think I have a mistake
can you show me what to config?
Thanks ,
Google. First result…
https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Destination_NAT
Upgrade RouterOS.
There are zero reasons not to do that.
… Except it is working somewhat now but after uprate something may change… Everyone has to test before an upgrade to be sure he will not make more damages than expected…
But sure, I have already suggested upgrade as an option.
I agree with Jarda
but about the NAT…
I want to be able to see in WINBOX the 192.168.1 router from my computer
so what NAT should I do ?
I don’t want to change the winbox port
Use dst nat. You need to use another port from outside and redirect it to right port inside.
But I can’t see it in WINBOX (which is what I want)
Save the session into managed tab and you will see it always. If you mean the neighbours, note that you need single L2 segment to use that functionality. It cannot work over nat from definition.
And again: the romon can help you too. But according to my opinion it is just a hole into the network so I am not using it at all.
Now the question is, why do you want to see all your routerboards from winbox neighbors?
Maybe try this, create eoip tunnels for all the routers outside your computers subnets.
Then just add them to the bridge of your router.
Winbox should see them in neighbors with no IP’s then you can just mac-telnet or mac winbox into them from your pc
Seems I need to correct my previous statement/joke. In recent RouterOS versions there is internal protection against damage, it will not allow you to set above EEPROM value. You can’t burn it :wink:
This belongs elsewhere…
